I don't understand the obsession people have with the coldfire.. it's just incompatible enough to screw everything up and offers little to no benefits as nobody will develop for it.
The nice thing about Coldfire is that they are the only chips around which are (almost) compatible with the 68K instruction set and are available for $30 and less in speeds an order of magnitude faster than are in the original machines. I don't think any other chips come that close to providing an affordable speedup for 68K based systems.
As I mentioned above, the problem with 68060 upgrades is that the 68060 chip costs about $300 each from Freescale. You could build an accelerator for them, but at those prices three people will be able to afford them.
Heck, I had an idea about building a copy of the PowerCache030 for SE/30s until I priced 68030 chips. The original 68030 chip is priced around $100 each depending on the speed. Building new accelerators around those chips isn't practical either, at those prices. That's not even counting the FPU chip to go with it.
You're correct. It is incompatible or, at least, not fully compatible. But, if one wrapped the hardware and software around it to make it compatible it doesn't matter if anyone develops for it. It would look like a fast 68K to the host Macintosh. Old and new 68K software would run on it. That's the dream. More about dreaming below.
The big attraction of the Coldfire is that presumably, most of the code would not be emulated. That depends on the actual instructions used in 68K programs, but it would be nice to have an accelerator which is mostly running object code natively without emulation.
trag - I know you've done a few nice projects, but an accelerator is a big job.
Yeah, my previous projects are not in the same ballpark, neighborhood, nor municipality as an accelerator. But I did mention in my post (see paranthetical comment) that it was a more of a fantasy and that for there to be any realistic chance of realizing such a dream I'd need a bunch of software guys to help.
On the other hand, in my experience, the trick to doing large complex projects is to rob them of their complexity by breaking them into smaller doable chunks. That's part of what I was trying to do in my previous post. We don't know how to make an accelerator, but we could compare the list of signals in two datasheets (680030 and target Coldfire). We can also compare instruction sets from two different datasheets. Those things are simple, though the latter would be tedious.
Once we had documented the differences, I'm pretty sure we could check the documentation of that 68K emulation library to see if it makes up the difference.
I know how (in theory) to map out the functions of the GAL chips on an old Daystar accelerator card. Translating it to functions it's performing on an active IIci or SE/30 bus would be more daunting, but mainly because one would need a strong understanding of how the 68030 runs its bus and communicates.
Once we knew all those things, we would (roughly) know how to connect the host Macintosh bus to GLUE logic (probably in an FPGA) which would perform the functions that the old GALs did, plus any new Coldfire specific logic, and connect that to the pins of the Coldfire chip. I've done FPGA programming so I'm pretty sure I could program a chip to perform as the GLUE.
I certainly know or can find from documentation how to connect a boot ROM (programmable Flash) to a Coldfire chip. I'm not as certain that all the unsupported 68K instructions can be made to generate exceptions. But that will be apparent from the chip's documentation and the comparison of the instruction sets.
Hooking up the USB and 10/100 ports is trivially easy. Connecting the DDR memory is more difficult because all the traces need to be the same length and mostly insulated from noise, which probably means on interior layers with power or ground layers between them and the outside world. This may create a need for a six layer board, blech. Prototypes with 4 layer boards are cheap (<$200 per three) Prototypes with 6 or more layers are much more expensive.
So, from my hardware point of view, I think it is doable. It would take a lot of time.
It is also possible that the initial documentation studies would cause one to conclude that it isn't practical. Perhaps the Coldfire I/O busses are just too different from the 68K. I'm assuming at this point, that they're fairly similar with 32 address and 32 data lines, plus similar or identical bus arbitration signals.
Maybe start with something simpler.. like a nubus USB board perhaps?
That is mainly a software problem.
There are USB chipsets which interface directly with a CPU bus rather than to PCI. So it would be fairly trivial to get one of those chipsets onto a NuBus card. It would need an FPGA (or at least a CPLD) to provide the GLUE between the NuBus and the USB chipset. In many ways it'd be easier to just build a PDS to USB board. There's a lot less translation from bus to USB chip that way but some kind of hardware interface between the USB chipset and the PDS slot would probably still be needed.
How do you write a USB driver after that though? Ideally, one would write it as a SCSI SIM so that the USB bus would be bootable. Know any 68K Mac developers who are bored and need a large software project? Writing USB drivers would probably be pretty large, I think. But if you can come up with some serious 68K/USB programmers, I'm willing to team up and support the hardware side. They're also going to need to write a SCSI Manager 4.3 type XPT so that the host machine can handle having more than one SCSI bus.
Discussion of XPT and SIM can be found fairly early in Chapter 4 of "Inside Macintosh, Devices" which is downloadable from Apple as a several PDFs (one per chapter, chapter 4 is titled "SCSI Manager 4.3).
What I'd really like to do is build an IDE board for 68K Macs. That's been kicking around in my head too. It'd be cool to have an interface for laptop IDE drives in the old 68K models. I just haven't made the time for it and now I've started a new job and have even less time.
I've been telling myself that when I finish assembling the last few IIfx SIMMs I have laying around here I'll start on the next new project, but the blank PCBs are still sitting on my bench. Sigh.
A flash SIMM board that could hold all 3 iifx/iisi/se30 roms would be welcome development too.
I already have a (non-writable) board design drawn for the ROM SIMM. I've never had it fabricated because it doesn't appear to make economic sense. I also think that I may need to revise it to put two chips on each side, instead of four chips on the same side. If one is hand soldering the chips onto the SIMM, one needs space between the chips for the soldering pencil.
It would cost about $600 just to have 200 SIMM circuit boards made. That's not counting the cost of chips. After that the SIMMs can be built one at a time as needed at a marginal cost of about $4 for the chips. It seems unlikely to me that there are enough folks wanting ROM SIMMs to make up the $600 plus $4 per SIMM even at $20 or $30 per SIMM, assuming they would pay that much. And that's not even considering the time involved. While fewer than 200 boards could be made, the total cost doesn't actually drop much or at all, the unit price just goes up.
And there's the issue that such a board would violate Apple's copyrights, though why any sane person would care at this point... Still, makes it kind of hard to advertise and sell.
If you want the board flashable as well, that would require hooking up the Write_Enable signal (assuming it's even present in the ROM socket) and the then coding up a software routine which can massage the Flash chips into writing their contents. That's software again, at which I am marginally competent, and more importantly, just not that interested. I can connect the wires. Writing the routine which will properly massage the Flash chips into being written does not interest me.
