660 questions, possible 840 as well
imactheknife
Does the av machines (all my 660av) choke on some game sounds, or crash with error type 1 with crystal quest. I know the cache can cause issues. All my 660 act the same way, havent tried the 840av. Will see.. is this typical behaviour from these machines? Sound works perfectly, cdroms play perfectly etc
tjjq44
It might be cache issues but 32 bits addressing seems more likely. Sadly AV macs can't do 24 bits addressing... That's why I don't use my 840AV as my "daily" mac, I use an accelerated (33Mhz 68040) LC 475 instead.
imactheknife
yeah for sure, well I have other machines so will use those. Just wanted to make sure it was a "normal" thing for the AV machines...
