Yeah, I actually have both types of external Zip100 drive (parallel/scsi). At least one of the two parallel ones I know works for sure, I've tried it on windows xp, I even managed to find the drivers from iomega for it (which was good). The little diamond with a horizontal dash projecting out of it (SCSI symbol) and the jumpers were a dead giveaway about the scsi one even before I saw the diagram on the back.
Byrd:
I'm pretty sure that a DB25 parallel printer cable is not the same as a SCSI cable; even if the pinouts were the same SCSI cables have much better shielding and thicker gauge wire. And lastly, yes switch the Zip drive to terminated as it is on the end of the SCSI chain (in this case, on it's own but still "the end").
I agree in theory.The reason I ask is because I'm not referring to a normal parallel printer cable, I'm referring to the Zip branded cable (I only happen to have one, maybe two) that is used to connect the parallel port version to a computer. It's DB-25 on both sides, maybe even DB-25 M/M. The thing is I figure if it's just a straight through 25-pin cable, and assuming SCSI doesn't have any special connector swapping inside the cable that makes say pin 3 on one end pin 4 on the other, then it should be fine. I'd rather be sure though, and not break anything. If it at least worked, then I could be fairly comfortable hunting for an actual scsi cable.
24bit:
Before discarding your HDD drive:
Is the 6100´s PRAM battery good?
Can you access the HDD after floppy boot?
Is your "dead" drive still seen on the bus?
Did you try to low-level format it?
I'm pretty sure the PRAM battery is fine, I replaced it around 1-3 years ago because it was causing video output not to work properly somehow. I haven't tried booting from a floppy I don't think, or I tried and it wasn't working (little fuzzy on that at the moment, I'll take another look at it later today). I am unaware if it's seen on the bus, I seem to recall that it just wouldn't boot up. The computer turns on and appears to proceed to booting (looking at them monitor), but then either can't find or can't read the drive somehow (floppy with question maybe?). I'll have to double check on a few things, since I put it down with my stuff in the basement awhile ago because it wasn't working, I just thought I might try an alternative solution if I could find one. I'd rather not format it just yet, even if it's possible, since it did have some software on it from the previous owner that I don't have a copy of (I've never had a NEW mac personally, I just happen to collect computers, including old mac ones). Sorry to say, but I don't live in Europe. In any case, I believe (I could be wrong) that the external scsi ports and the back of the device are both DB-25.
I wish I had the money and luck to acquire a working SCSI drive, even if I needed an adapter, since the 6100 only has a 500mb drive and can theoretically take a 2-4GB drive at least, if I had system 7 or 7.5. The space might be an issue though, the performa's drive are packed pretty tightly and mine has a pc/dos card in it with, I think, a 486 on it that takes up some of the space inside the case. Almost wish i had a scsi drive, just so I could see if my recently acquired old powermac g4's scsi card would be able to read it. That and I also WISH I had a working cd-rom for the 6100 (mine seems to be stuck/jammed and/or broken) and a copy of os 8 or os 9 because the performa ought to be able to handle it, if pathetically. If wishes were money, we'd all be richer than a saudi arabian prince. :lol:
Thanks for the help guys, I'll get back to you after double checking on booting a floppy and see if I can get it to start up some kind of system disk.
