Thanks Mac128 , I think You found the problem. According to Apple Support my sony drive needs the ”B” ROMs. ” "-B" ROMs are only compatible with the Sony OA-D34V-22 or OA-D34V-02 drive. Earlier drives "OA-D34V" used the "-A" ROMs”
http://forums.macrumors.com/archive/index.php/t-1539356.html
The problems is that it wont work with my ”B”ROMs.
I have tried both the internal floppy drive (Sony OA—D34V-22) and an external drive (Apple M0130) connected to a Plus board ( ROM HI: 342-0341-B, ROM LOW: 342-0342-A) and everything is working perfect. Now I have two 512k boards to test.
The first 512k board (512k1) was together with the Sony drive in the Macintosh that i bought on Ebay. It was sold as not working so that is OK.
512k1 board is number 630-0118, ROM HI: 342-0220, ROM LOW: 342-0221-A. When I connect the floppy drives it will not boot. Just happy Mac, disk is spinning but stepper motor not working.
Recently I purchased another 512k board (512k2) sold as not working. 630-0118, it has ROM HI: 342-0220-B, ROM LOW: 342-0221-B. The same result when trying to boot from floppy.
The ROMs are cleaned and reseated , swithing the two ROMs between the 512k boards made no difference.
Obviously it may be better to buy working Macintosh instead, but it would be interesting to locate and solve the problem if possible.
Is it safe to put the two ROMs from the Plus board in the 512k boards?? Should it work?
Is it common that ROMs are defect??
Many thanks for all Your advice
