3D-printed 68030 CPU Puller
obsolete
After bending a few pins by using a DIP puller to remove PGA 68030s from sockets (I know, I know) I decided I needed a better tool. I thought I'd have to design one myself, but I found this 68040 puller tool by jessenator on Thingiverse. I was able to scale it down to 68030 size, and it works great! It fits the SE/30 just fine; slides right on over the GLUE chip. Hopefully it will work on most other 68030 Macs as well.
obsolete
The numbers are shown in the photo above, but for convenience, I'll write them out too:
X: 40 mm (73.39%)
Y: 39.2585 mm (100%)
Z: 35 mm (80%)
Of course, this is dependent on my printer, which is relatively well calibrated, but not perfect, so your results may vary slightly.
obsolete
Follow up to this: it requires a lot more force to pull a 68030 straight out of the socket than it does to gradually lever it up one side at a time, and the latter method doesn't bend any pins if you're careful. I wouldn't recommend using this tool without first loosening the chip by levering it up a little first.
