About 9 days ago, my 1400cs froze while I was using it so I restarted it and it would no longer boot. I booted off the OS 9 CD and it offered to initialize the disk. I declined and ran Disk First Aid on the disk. Note that I am using a 2GB Compact Flash card via a Compact Flash to IDE adaptor as a hard drive. It said "Problem: Keys out of order, 4,365" and Disk First Aid was unable to repair it. So I formatted the drive with Drive Setup and did a clean install of OS 9. It was fine until today. I started having problems with error messages, then the Finder could no longer be started because of something to do with the system file "ObjectSupportLib". So I booted off the OS 9 CD and ran Disk First Aid and got the same error only the number is 4,258. It still boots this time, but since the finder can't be started, it doesn't really matter. This could be a coincidence, but this happened both times while I was working with MacWrite files I wrote on my Macintosh Plus and transferred over via floppy. Why did this happen ago so soon? Is it a problem with using a compact flash card as a hard drive? Or a problem with the compact flash card?
