Soldering iron recommendations
3lectr1cPPC
I’ve still got one of these: https://www.amazon.com/SOLDER-STATION-40W-120V-ST3/dp/B000AS28UC
Got it as a starter iron back in 2019(?) and learned to solder on it. I’m sure there’s a lot better stuff out there but this one works well enough that I haven’t felt the need to get a new one, instead I’ve just expanded my tool library.
Got a Hakko FR-301 desoldering gun, works well I’d say. Hard to create any tool that does well on P4 motherboard ground planes…
The hot air station I’ve got is a Quick 861DW I believe. It’s remarkably quiet! Haven’t used it that much but it seems to be pretty high quality, works great the couple times I’ve needed it since getting it a couple months ago.
smrieck511
Well I loved this Pinecil for a year and suddenly it doesnt detect the tip anymore? anyone ever seen this problem or know how to fix it?
Unknown_K
Does the thing come apart? I would guess the temp sensor is nonfunctional (it is a temp controlled iron correct?) or the heater is broken.
smrieck511
yeah, it does come apart and I've tightened the contacts and cleaned up everything. Re-inserted the tips several times.… No dice.
smrieck511
I know this sounds weird, but I think I figured out what I've been doing wrong with the Pinecil...
I have two dead tips. The iron itself is fine.
The tips stop working shortly after I clean them using fine grit sandpaper which I know sounds stupid, but I've done stupider things…
Not sure why this would happen, but it can't be a coincidence that two tips went bad right after doing this. Thankfully, they're pretty cheap to replace.
