Well, it's spinning fasterI added a few drops of oil to the bearing in the IIcx power supply fan. I don't think it made any difference though. Check out the before and after and tell me if this sounds normal.
before:
after:
I usually run them for a while face down (out of the case if the case doesn't really allow for it) so the oil can work into the dry grease.
It usually works, my LC fan went from loud to near silent.
