Consider upgrading the ROM, you can find kits on eBay and elsewhere. You'll need to upgrade beyond ROM 255 in order to use Smartport hard disk images like Total Replay.
Yes I do plan on doing this at some point! However it looks like that's about $80 and requires some soldering (which I am very bad at), so I'll have to build up the courage for that
I have been using ADTPro, it was honestly surprising how easy it was to get working! I have about 10 floppies that I've been swapping around with various software.If you don't get one, then I suggest checking out ADTPro. This will allow you to connect your Mac or PC to the Apple II and write disk images to it.
IIRC it’s one trace to cut, and one bridge to solder. The soldering is the easy part! It does not require any precision. Cutting on the other hand: you don’t want to slip! But it’s not in any way delicate work.Yes I do plan on doing this at some point! However it looks like that's about $80 and requires some soldering (which I am very bad at), so I'll have to build up the courage for that![]()
You literally flip them over and notch it. Or you can install a write-protect override switch onto your floppy drive, then you don't have to bother with notching. Some disks come pre-notched and pack of stickers.Dumb question about 5.25" floppies - if they box says they're "double sided", should they just work if I flip them over? Or do I have to cut the "notch" on the other side?
is there anyone near you that can help? Someone with a desoldering gun and an EEPROM writer wouldn't be too bothered about helping. It shouldn't take more than a few minutes. Take longer to drink their coffee.Yes I do plan on doing this at some point! However it looks like that's about $80 and requires some soldering (which I am very bad at), so I'll have to build up the courage for that![]()
Mine have one notch and the stickers - the stickers are for making both sides read-only, correct?You literally flip them over and notch it. Or you can install a write-protect override switch onto your floppy drive, then you don't have to bother with notching. Some disks come pre-notched and pack of stickers.
I just watched a video of it, and I was definitely thinking it would be harder than it actually is! Nice big spot to use way too much solder onThere's no "serious" soldering involved. See my walk-through of my own IIc's ROM upgrade here: https://www.bigmessowires.com/2015/05/29/apple-iic-rom-upgrade/ Cut one trace on the PCB, and add one solder blob to a giant solder bridge on the PCB. The solder bridge is huge and impossible to mess up.![]()
