New Accelerator for Apple II-series soon available!
Oh, man, it looks like the IIc RAM/clock card is back in stock. Do I order it now, or wait until I get around to doing the ROM upgrade I'd need to use it first?
I have to second those that are hoping a IIgs version of this accelerator materializes sooner or later, especially if he manages to price it in the same $150-ish ballpark. Unlike the IIe the IIgs really needs an accelerator pretty badly to show off what it's capable of, and $150 would seriously undercut the normal going rate for one.
I wonder if I should get one of these?
I have a II Plus and a Platinum IIe. Would this work in the former?
c
Nope, 2E only. And not much Basic speedup according to a current Facebook thread. ROM is still accessed at 1MHz speed. You can load ROM into RAM, but it's the same RAM Prodos uses, so it's one or the other.
I want one! Where can I pre-order? I have an apple //gs and having a 16 Mhz CPU will give my system 6.0.4 a sweet and beautiful experience!!! Will future project have Ethernet card?
Yeah I doubt they will be making anymore of those. I sorta need an ethernet card because I intend to develop a GS-IRC client and I need one to test the program out.
He’s working on more right now. I’m on his email list, and he sent out an update a few days ago.
Do you intend to target the Marinetti TCP/IP stack? Possibly worth nothing: Marinetti supposedly has support for MacIP protocol over Localtalk. I have no idea how well it works but I did muck around with it briefly and found it did at least *appear* to be picking up an IP from the MacIP bridge software that was running on my Raspberry Pi. (Didn't get much further because when I toyed with it my IIgs basically didn't have enough RAM to run anything but the stack.) If you want to muck with it yourself Localtalk->Ethernet bridges are pretty cheap. And, of course, you also have the option of using PPP or SLIP.
OK
I have a question about the localtalk->ethernet bridge concept....do I have access to the internet via tcp/ip concept? Can I hook my apple //gs directly to the router and poof I can login? Does it see the IP address and gateway? Would I be able to ftp and do irc through it? If so..where can I find the hardware you speak? Does marinetti support it and works with it easily? How does it work exactly?
Okay, I get it, you're not interested.
(And answers starting from the top are roughly: "yes, if you have the routing set up", "no, unless you're using some pretty obscure hardware/software solutions for your router already", "yes, if MacIP routing is set up on your network", "if software exists for Marinetti that does those things, presumably", "on ebay, or theslownorris has a couple listed for sale here", "here is an account of marinetti's MacIP support working with a Gatorbox, a common hardware MacIP router so, yes, it works and "'easily' is slippery word, see the last answer", and "MacIP is a method for encapsulating TCP/IP inside of Appletalk packets, which was commonly used back in the day to get classic Macintosh Localtalk networks onto the Internet. You need an Appletalk router to do this; there are hardware ones like GatorBoxes or a few old Cisco routers, or a software one. There is software that runs on real macs, so if you have an old Mac you can use that for both the router and the Ethernet/Localtalk bridge. Otherwise you can pair software like macipgw, which can run on Linux or xBSD and is available in pre-built VMs with the hardware ethernet-localtalk bridge, which *only* bridges Appletalk-format packets without any protocol translation and leave the TCP packing/unpacking to the router software.")
But, again, whatever.
I think there is a huge miscommunication here and what are you thinking is completely different than what I was thinking. I just felt like I entered a twilight zone and go about and say "What just happened here?".
@_@. Interested in what exactly? I offended you how exactly? How am I a bad person again? And what in the blazes are you talking about? I am trying to communicate in English here but I doubt there was anything close to that language here.
All I want is a hardware that hook my apple //gs to the internet via ethernet and tcp/ip. If it requires me to have 4 year degree of bachelor of apple //gs and then another 3 years to have a master to do it..then that is fine with me...I will not bother with network and just enjoy watching people do it on youtube and always ask how they did it and why I can't do it. I mean I am ok doing it this way also, really. I am fine with it.
I apologize. The problem with plain-text communication like this is that occasionally the same text can be dramatically misinterpreted in tone, and apparently I took your excitement as sarcasm. Seriously, if it wasn't meant that way, I'm sorry. So I'll start over, kind of.
Per my unnecessarily cranky answers above: using a MacIP router plus some sort of Ethernet to Localtalk bridge is the closest thing you can come to having an IIgs just "plugged into the network" short of one of the extremely rare Apple II ethernet cards. The downside is that it isn't a self-contained solution: you need some other widget in the mix, the specialized router, to handle the TCP/IP encapsulation/decapsulation.  (The reason I interpreted your reply as sarcastic is I thought you were coming down on me for suggesting it *because* you knew that it has that external dependency and were making it clear that any solution that wasn't completely contained inside the IIgs was unacceptable.)
If you're fine with that dependency then, well, if you're looking to write native IIgs software (IE, using the GS/OS graphical user interface instead of something self-contained like Contiki) the programming interface (IE, the Marinetti TCP/IP stack) is the same. Therefore if you used this setup instead of Uthernet card to write your software your programs *should* also work for someone using an Uthernet. (Or PPP, or SLIP, or whatever other link-layer drivers the stack supports.) Using a bridge instead of Uthernet also has some non-TCP-related advantages; for instance, there is no Appleshare driver for Uthernet, which means you can't use Macintosh file sharing protocols. The Apple IIgs and GS/OS actually has excellent Appletalk support built into it, including the ability to boot over a network, and there exists a wonderful easy-to-use software bundle to make use of it.(*) Therefore, even if you're not interested in TCP/IP at all a localtalk bridge can be really useful if you're a IIgs owner.
(* Note also: the latest versions of A2SERVER can automatically set up MacIP on Rasbian and Debian, although I can't personally vouch for it yet. So if you set up A2SERVER you might get your MacIP router for free.)
The going price for the bridges is still only about $20-$30, so even if you buy a Raspberry Pi solely to dedicate to your IIgs the cost is still less than an Uthernet card, if you can find one. Downside is you need to learn some stuff about MacIP network routing to get it going. If you think you're up for the challenge by all means go for it, don't let my mistaken crankiness discourage you. Again, many apologies.
(When I get some free time I'm intending to fire my IIgs up again and play with it myself, but until then unfortunately I can't be a whole lot more clear on the specifics of what works and what doesn't on the IIgs end. I know I was having issues in part because a standard 1.25MB ROM 01 IIgs just doesn't have enough RAM to load all the software stacks needed for NetBoot/Appletalk *and* TCP/IP and leave enough left over to run anything useful. If you're really interested in programming TCP/IP on a IIgs you'll probably want at least 2MB of RAM.)
I don't want to use contiki or anything like that..I only want to write native //gs software that is dependent or need GS/OS graphic user interface and need the tcp/ip connected from within the gs/os (whatever driver etc) and it is an OS application and not outside the OS application. I want Marinetti TCP/IP. I want to be able to go inside the GS/OS...go to the setting, click tcp/ip..click connect..it connects...then write an application inside the GS/OS with GUI and everything and call it GS-IRC that access the network through GS/OS, Marinetti TCP./IP if this is the one that does the job.
I don't want a bridge. I want tcp/ip. What I want is an Uthernert card and tcp/ip configuration like I do with windows or heck even Amiga.
Concerning the RAM issue...I will not tackle the programming yet until I have completed all my hardware purchases. I still need to buy the MicroDrive CompactFlash and finally a 4 MB RAM expansion. Also I do want to buy the uthernet and login to the internet in the native environment of the GS/OS and full GUI in everything and start coding there. I didn't realize there is already an ftp for gs called safe2. So I am going to install that into my GS and also there is an outlook express like program for the //gs for GS/OS I want to configure that and get my emails in there so i can read them from my apple //gs.
The amount of .....pleasure......release of pleasure chemical in my brain when i do this...is unbareable and make me ever so much more want to write serious and useful application for GS/OS. I want Apple //gs to compete against Mac 68k and I want to write very useful application for the GS/OS. I have downloaded 1 GB worth of pdf all about how to program for the Apple //gs.
I am going serious mode here. Honestly, I was not even understanding half what you said before so there is no way I will be sarcastic to something i don't even understand to be able to be sarcastic about. I just want a network solution for my Apple //gs to be able to go online inside the GS/OS using tcp/ip using the GS/OS GUI much like I do with windows or linux and then go online that way.
Three programs I want to write for the Apple //gs:
A) System friendly ftp program where even if you run the ftp program you can still run accessories and do whatever you want in the desktop of gs/os.
B ) System friendly IRC client program. You can switch windows between it and the FTP...you can chat inside the GS/OS environment and still do ftp stuff at the same time. I want to see what modern features we use now in ftp and try as much as possible to mimic it for the GS/OS.
C) Write a movie player with it's own format and be system friendly for the GS/OS <-- If I have to...I may need an accelerator to make this happen..which is why I am in this topic...want to pre-order or buy an accelerator.  By the way, don't say it cannot be done. It can be done. Commodore 64 already have it's own video format and runs movies in 16 color...what I will have is a 16 bit application gs-slider (I call the application slider) and it will use 256 colors or 4096 colors if possible to play movies verses the limitation the commodore 64 have when playing movies only in 16 colors. I want to know what hardware limitation when it comes to //gs when displaying how many colors per picture and use the maximum number of colors to play movies.
I know I said 3 but I have extra I just remembered to add them here in the list
D) In the future I want to write GS/OS network games like sudoko, bagammon etc I want to do the same for Amiga actually. It will be the same game ported for Amiga and //gs and you should be able to play cross platform between the system
E) I also want to write a skype like program for the GS. It will have emoticon gifs display and you chat with people back and forth and add friends like skype but no video or audio support. Only because there is hardware limitation behind it.
I am doing all of this because I am hoping it will bring fresh new blood to the community and make the Apple //gs shine the way it should have shined. I have no doubt that the //gs is even more superior than the mac 68k in all regard....I would say //gs is really psuedo mac and because it is mac system..I see no reason why it can't give you everything a mac could including and up to photoshop program. And no...I am not being sarcastic here!
By the way that is why I am so happy my apple //gs is rom03! It is a ROM fit for gs/os and that is what I want!
Not to belabor the point, but "TCP/IP", strictly speaking, doesn't have anything to do with Ethernet, other than Ethernet happens to be the most common physical layer it runs on. Marinetti running MacIP on Localtalk is just as "real" a TCP/IP stack as anything else. (TCP/IP also runs on various serial link layers, IBM Token Ring, Arcnet, and any number of other obsolete network hardware protocols. I didn't list WiFi here because it can be *mostly* thought of as Ethernet-over-Wireless, but strictly speaking even that isn't entirely true.) When you use MacIP as the link layer in Marinetti you get a TCP/IP control panel that looks essentially the same as the one presented to you when you use Ethernet, and to software running on top of the stack the connectivity looks exactly the same.
But, sure, if the work to get the MacIP router set up sounds too difficult then by all means pursue the option you think you can handle.
It seems a bit counterproductive to scorn the most accessible route to getting TCP/IP on an Apple IIgs then, if your goal is to encourage wider enthusiasm in the platform but again, sure, whatever floats your boat.
It is not really scorn..more along the line of wanting everything looking pweaty in gs/os.
There is just something about that OS that make my saliva foam and I......I lose all control! I want MORE GS/OS APPS...MORE MORE MORE MORE...MORE GS/OS GAMES inside the GS environment....more! i don't think I can have enough....I am like pacman who want to eat those pills...more and more
But it all looks the same in GS/OS regardless of what link layer you're using to get it access to the network. The only difference is what kind of wire comes out of the back of the computer and whether it crosses another box or two before it gets to the Internet.
k. So be it. I will go to your approach then. Can you send me link of pictures of how it look like and I will get the hardware online via ebay? But I don't want to use raspberry though...can I use my PC or something beside raspberry pi...do I really need raspberry pi for this? Sorry if you have already answered all of that but all that text went out of my head..the termonliogy made me have a headache. Seriously, treat me like a 3 year old here and take me through it step by step. Like this:
Step 1:
<information, link> in one or two lines...
I do step 1 I update you...you take me to step 2:
and so on.
Pretty much hold my hand on this...
