Mac CC InstallMeFirst Disk
MarNo84
Hi,
I'm not sure if this is the correct section...but I'm hardly looking for a working german Version of the Mac OS 7.1 - Spezial Installation (InstallMeFirst Disk - or Dc42 Image.
My physical Disk is broken; physically, no way to read or write on it. I already swapped the magnetic inlay/inner disk. So now I just need the correct content.
The Internet in its glory isn't a good shot this time..I can't find any localized german Colour Classic Disks/Images :-/
Anyone here in the Community owning a set of German Mac OS 7.1 for the Colour Classic?
Or..does anyone know a good source? (Already tried the MG without luck)
Marcus
Hi,
well - this is a good page but that would be only MAC OS 7.1 in retail ..so usable for every Macintosh that supports it - sometimes with enabler.
These "InstallMeFirst" Disks provide just that Systemenabler before/while installing MAC OS. With a retail OS Disk I can't install the System :-/
It's not the OS I need - I just need that single Disk  [:P] ]'>
It's probably a matter of finding the right enabler(System enabler 401) and modifying the retail disk to suit.
I have a disk of the French Disk and the enabler IIRC, so probably a small modification to fit.
Yeah that was my first thought and attempt to try ;) I used another language Disk and it won't work because the system looks for the Name of the Disks and Files in localized language. I also tried an Quadra and LC InstallMeFirst Disk - it will boot up and therefore install but won't copy the enabler to the hard disk - still a manual job to do :-/
So it's still neccessary to get the correct language version
I hope I found your file. I put a slew of System 7 stuff here for you, https://drive.google.com/open?id=0B32C6NlrH1VXaHNUWkxia19wbnc
I apologize that the amount of stuff is huge but some are sit files and I am honestly strapped on time a bit. Please check if what you need is there. If not please let me know and I will dig deeper.
Please note: As I edit this, the upload continues to Google Drive.
Just gonna add some more material mentioning System Enabler 401.
Contents of zip file. on Color Classic and System Enabler 401, required for System 7 and 7.1 only..zip
System Enablers: Current Versions & Change History
Last Modified: October 20, 2000
Article: TA28948
Old Article: 11491
This article lists the current versions and the change history of the Macintosh system enablers.
Macintosh Color Classic: Technical Specifications
Last Modified: October 13, 2008
Article: SP207
(mentioned system enabler 401 requirement for System 7.0 (Pro) and 7.1)
System 7.1 through Mac OS 7.6: Compatibility With Macintosh Computers
Last Modified: April 20, 2004
Article: TA47341
Old Article: 8970
The table in this article list Macintosh computers and the versions of System 7.1 through Mac OS 7.6 that can be used with them. It also lists versions of any required enablers.
System_Enabler_401_1.0.5.sea.bin
Hope this helps.
I will try another language version, then when the CC is up and running, i will swap both System and Finder files to the german ones, worked for me several times, you will have the localized CC you are looking for.
