Odd Power Macintosh 7xxx? Setup
Last in the odd series. Found this PPC without a label, looked inside and found a few fun things.
What secrets are on that HD? - very nice find.
Unfortunately the HDD was DOA. It's completely dead, so I'm trying to swap HDD pcbs on it to see if that works. (I tried a direct swap with another one and it booted, but I think the head is messed up or something)
In other news, I booted the Mac up with MacTest and the following came out of it:
It read the model as a Power Macintosh 8500 with a Production date of Jan 2nd 1989 lol.
The CPU card is an Apple 604EV 400mhz card
Interesting to say the least!
Very Interesting. Although the 8500 was a tower style case. Also the 8500 had a max clock speed of 180 mhz whereas this is a 400MHZ. This could have been an unreleased Mac based off the 8500 motherboard.
Interesting indeed, does the processor card have a date on it anywhere?  If memory serves me there weren't any shipping machines (from Apple at least) that had a 400MHz 604ev.
Do you have a pic of the entire logic board? 8500 and 7600 shared virtually identical logic boards.
Edit: But yeah, it says 8500 right there on the board.
Sure. It's also worth noting that the card itself has 300 mhz crossed out and 400 mhz put into it's place. I was curious, so I looked underneath the heatsink and it was a a 300mhz EV Engineering Sample with 1MB cache. So I guess they overclocked it.
The 7500, 8500, 7600, 8600, and 7300 motherboards were all physically compatible.
Is there A/V hardware on it? If so it could be an 8x00 board. It would be neat to hear that Apple had been developing something faster than a /200 for the 7300.
Not quite, the 8600 and 9600 boards support the faster 604ev CPU cards, the earlier boards don't. You won't get any life out of a x500 machines if you swap in a 604ev card.
The bios/rom read it as a Power Macintosh 8500
It looks like it has the header for the AV ports (34 pin connector above the first PCI slot) but it's definitely not a standard 8500 board since the connectors at the top of the board are perpendicular as opposed to parallel to the board and the connectors for the speaker and front LED are different as well (see below for a standard board)
I'm wondering if the previous owner swapped the ROM SIMM for an 8500 into a 7xxx board.  I've never tried it with mine since my 8500 is packed away far from me but it seems reasonable that if you did that the machine would identify as an 8500 as opposed to whatever this is / was supposed to become (7700?)
 I actually recently heard something different from defor, although we didn't get into the details of what's happening. I'm going to be trying ot get an 8600/300 this summer so I can take a look at this and try to get it going then.
Of course, the 8600 and 9600 have the non-mach5/ev variants that accept all the same cards as the older powersurge systems and all those cards should work on those earlier boards, and possibly the mach5/ev versions.
It looks like it has the header for the AV ports (34 pin connector above the first PCI slot) but it's definitely not a standard 8500 board since the connectors at the top of the board are perpendicular as opposed to parallel to the board...
Unlikely to be a swap as the board isn't any sort of standard board. The 820-0391-02 P/N doesn't align with anything, it's blue and it has a 400 MHz unreleased CPU. Add in the unmarked chassis, the "Test Purpose Only" hard drive and "Sample for Evaluation Only" CD and we get a prototype for an unreleased machine of some sort.
[NITPICK]
1)   The 7500, 8500, 7600, 8600, and 7300 motherboards have the same form factor, but the 7600/8600 changed the power supply connector.  The 7300 uses the 7600 style connector.
2)  There were two version of each of the 8600 and the 9600.   There was the original 8600/9600 with the 343S0280 - 343S0283 ROM chips and cache on the 9600 logic board.   These original models use the same CPU cards as the X500 machines.
Then there were the 8600 Enhanced and the 9600 Enhanced, which are also called Kansas machines.  They use the CPU cards witht he Mach V PPC604ev CPUs.   They have 343S0380 - 343S0283 ROM chips.   The 9600 Enhanced has no cache chips on the logic board but otherwise (except for minor rearrangement of CPU slot pins) is identical to the earlier 9600 logic board.    I have never mapped it out, but I suspect the only real difference in the CPU slot pinout is more 3.3V supply pins on the Mach V cards.
3)  ROM for the 8500 and 7500 and 7600 (and 9500 and most 7200s) were identical.   So moving a ROM DIMM from an 8500 to a 7500 or 7600 would not change anything.    Moving said ROM DIMM to a 7300 would make a change, as the 7300 uses the same ROM as the original (non-Kansas) 8600/9600.
[\NITPICK]
I suspect what the OP has there is a 7300 variant that actually supported the Mach V processor (changes in the CPU slot pinout).   The 7300 came out with the 8600/9600 Enhanced, IIRC, yet had the ROM of the original 8600/9600 and did not support Mach V.
It would have made sense for there to be an unreleased 7300 which was consistent with the 8600/9600 Enhanced and had a Kansas motherboard supporting Mach V CPU cards.
That 820-0391-02 P/N doesnt come up, but 820-0391-A is 8600.
I am thinking it couldve been a testing machine before G3?
Does the CPU actually show 400mhz because I was looking on one of the photos its showing 300mhz on one of the jumpers even though it is texta'd as 400mhz? I am interested to see the CPU to see whats the difference is..
Cheers
AP
