power macintosh 6400 not detecting floppy drive
hello, i have a power macintosh 6400 with a sonnet G3 upgrade and 104MB of RAM (also looking for two 64MB sticks of 5V EDO DIMM memory for this thing that don't cost a fortune...), and the machine is quite nice. however i have experienced an issue recently after i turned the system on after a while of it being off (like a few months), and i noticed the floppy drive is not detected and won't seem to run. oddly enough sometimes i can hear it spin up on boot but then it just stops. tried 2 different drives, same result. what could be suspect here? last time i used it, a few months ago, everything was working perfectly fine... so it seems strange that the floppy system doesnt seem to work anymore. also note this, the board is from a 160mhz performa 6360, which uses the same "alchemy" platform
