Macintosh II - powers on immediately
egrath
Hi,
I have a Macintosh II here that I got as DOA. Recapped and cleaned everything, looks good so far. However, one issue remains:
The device powers on as soon as voltage is supplied to the power supply. Also Soft-Power-Off does not work.
Any hints on what I can check first?
With kind regards,
Egon
Can anyone please tell me if a voltage output of 2.8V on UB2, Pin 3 is normal when batteries are inserted, but the logicboard is otherwise don't connected. I measure from B2 negative to the UB2 Pin 3.
And is it normal that when measuring from B1 negative to UB2 Pin 3 that there is no voltage difference at all?
And one additional question: Does someone know the pinout of SW1 and how to check if it's hanging?
