Portable Preventative Maintenance
Hi all,
I know about the importance of re-capping, using correct batteries and power supplies, and sorting out the stock hard drives on the portables.
Aside from those and the typical keyboard & trackball filth and mechanical issues, what else "should" be done generally on a portable?
Off the top of my head I wonder about two things -
I've read about the frailty of the 5126 video cable. Can this be reinforced somehow? At what points and with what?
Does the hinge or clutches need to be degreased and lubricated like on PowerBooks or is it a self lubricating plastic assembly?
What else?
Thanks!
Yes, I read your thread on the subject. Does the metal inside those clutch assemblies commonly need to be stripped and lubed?
