CF in Takky?
MJ313
Takky interests me... 3.3v regulator does not :) Some boards, like the 6500, apparently you can get away with not using a 3.3v regulator if you don't push the board too much and forego PCI. 6400 boards seem to require the regulator regardless and I *think* this is due to power draw?
I am wondering if using a CF to IDE adapter would reduce power draw enough to allow 6400 to work without a 3.3v regulator?
Also, in 2017, are there better (easier) options for use as a secondary power supply?
I don't have a takky and this is more just an entertaining notion at the moment.
you could always just solder the 3.3v regulator onto the board itself. This guy:
http://www.newark.com/tracopower/tsr-1-2433/non-isolated-board-mount-dc-dc/dp/86P6889
Works perfectly. Thanks man!
