My parts drawer with the ROM SIMM versions is MIA ATM, but dougg3's note is in its slot. He sent me a IIvx set to try for the Rocket-in-IIsi hack, saying it didn't boot his IIci. Don't recall, but it probably didn't boot my IIsi and I didn't have an SE/30 to try that at the time. I don't really expect it to work when I do find it. However, the IIvi is 601 compatible and given it's intentional laming by Apple, its ROM is likely a closer match to the SE/30's than that of its faster stablemate. bbraun's info on the chipset (memory controller?) limitations he observed while playing with the 601 will probably come into play. Dunno when that changed, likely at the switchover to 72pin SIMMs. The fact that Apple lamed the controller to disable Cache installation in the IIvi's slot might get its ROM past that part of the hardware check in the SE/30 and the system buses are the same clock rate, IIRC.So far I tried it two different ways to use the Turbo 601 in an SE/30 with a IIfx ROM. One way was using the Daystar PowerCache IIsi adapter. The other way was plugging a IIvx adapter into the CPU socket and soldering a new power connector (temporarily) to the back side of the motherboard since the IIvx adapter got in the way. I thought maybe the direct socket plug-in would be the cleanest point of installation.
I heard the Power Mac chime which was exciting, but the screen was just black and I could not tell if anything was happening.
Thank you! I’ll start looking in to it!I'd love to get my hands on a Turbo 601 and test.
From what I've heard, it's possible. But we don't know the exact setup.
I'd say you need a 32 bit clean ROM (IIsi or IIfx) and a twinspark adapter.
And there are different versions of the 601 in existence: 66Mhz and 100Mhz. And the ROM is different.
So many things to take into consideration!
EDIT:
Interesting sites:
https://mac68k.info/forums/thread.jspa?threadID=280
http://web.archive.org/web/20040415145546/http://www.brinnoven.co.uk/turbo601/miscinfo.html
What’s the spec on your 601? And you’re right this topic should probably move -- didn’t know there was so much ROM-fiddling involvedInteresting stuff about the ROM, patch ROM and host ROM check setup. tt's info about using the IIvx adapter shook something loose in the ole noggin' that might be worth a try:
Based on this unlikely series of WAGs, I'd give the IIvi ROM a try in the SE/30 if I had any interest in this endeavor. No programmer or image available here anyway, so that saves some time!![]()
edit: hrmmm, was the IIvx adapter the same as the IIvi's, do both plug into the CPU socket of the MoBo? Wondering about the differences between that adapter and the DayStar SE/30 adapter?
BTW: this subject matter would probably get a lot more attention if it were kept in hacks where it belongs, 601 upgrades have nothing at all to do with Compact Macs after all. :beige:
I suppose this means that, in theory, one could try to use a ROM-inator II to get this to work? :O Not like I can do that, but perhaps someone in the world can?If a IIvx ROM can somehow be tweaked to boot an SE/30 to begin with and then get that combo to fool the Turbo601 into thinking it's in a IIvx there might be the remotest of possibilities of fulfilling the SE/30/PPC dream . . .
I did a similar mod to my IIcx, thanks to dougg3 here. Too bad I missed my chans buying the 601 this time. But I since I already have the ROM-inator, I’ll buy one as soon as possibly!We've got a flicker of hope again.
Thanks to beddy's thread about foreign ROM SIMM problems in the SE/30 we can toss out my negative result testing the IIvx ROM SIMM in the SE/30. His reported symptoms jibe with my results testing IIvx in SE/30 done under 7.5.5.
Mac SE/30 with upgraded ROM
Not my hack, but if someone with BMOE's toys wants to play with this crazy notion have at it! []
BTW: hacks threads really need to be located in hacks. This thread was a PITA to find just now and it hasn't even sunk below the first page in this forum yet.
