Ok, long story short: Bought an SE off of Ebay that had the blinking ? folder. I knew it meant bad drive or no drive. No problem. It had no internal drive, but the floppy worked. I made a system rescue disk, booted up, took a look at the specs (2MB RAM, etc.). Cool. I'll get a 50 pin SCSI drive. Got one, took the case off, and in the process of pulling the power connector off the logic board, the back of my hand smacked the CRT. Didn't look like anything was damaged. I noticed the metal frame inside was really rusted out, due of course to the bad battery. I pulled it out and it had corroded things quite a bit but the logic board and every thing else seemed ok. Put everything back together, flipped on the power and got a nasty screech from the machine with no video. Did some troubleshooting (disconnected the speaker, new drive, etc.) but determined it was the CRT as that's pretty much where the sound appears to be coming from with the speaker disconnected.
What do you guys think that I did, and from the above symptoms do you think it's something easily repairable/replaceable? Was it just coincidence and me routing around inside messed up a connection that might have been just hanging on by a thread until I got my big fat hands in there?
I did look through some of the topics that I thought might have had an answer but didn't see anything that seemed to apply. If this has already been answered elsewhere, please direct me to the info.
Thanks in advance!
Thanks in advance!
