Ever Heard of cc:Mail?
Nope i have my own unrelated 500 series hard drives that I've never been able to find a way to copy data off of. I tried scsi adapters but they didn't work. In fact I was thinking about using this machine for that purpose.
After sacrificing many brain cells to the SCSI gods, I determined that termination of the 2.5" drives seemed to be the critical issue. The 2.5" SCSI drive finally worked when I used a 54 to 50-pin plus power adapter in an external SCSI enclosure that has automatic active termination plugged into my Wallstreet.
I'm hoping that some day, someone gives me a WORKING 500 series to recycle. Then I can pop my drives in, copy anything readable off of them, then send it all on it's way.
I have a working 2.5" SCSI to 50pin adapter here. I don't recall having to do anything out of the ordinary to get it to work on a regular desktop SCSI machine, just make sure the end of the chain is terminated even if its a CD-ROM drive with a termination jumper.
or if you have an old IBM or toshiba power supply, they are usually 15V enough to hack something together to make a blackbird laptop work. Been there, done that.
I've got nothing but modern magsafe power supplies. and I'm also no good at soldering or board level electronics in general. I can't believe I have a need for one of these. I threw two away years ago thinking theres zero chance ill ever need one.
Ok the customer bought ANOTHER powerbook 500 and that power adapter was able to turn on her machine no problem. I copied her hard drive to my 7300 and after copying a system enabler, my fast mac boots right up off her old data!
So, back to the point of all this... how can I get these mails OUT?
It appears that this program lets you print groups of email. I'm going to try to install Acrobat, so I can "print" all these emails to PDFs. I'm not sure it will work, but I'm going to give it a show.
Separate from that, I'm open to any ideas anyone might have about getting this mail out "for real" and into a modern mail program as real email messages. That would be the ideal way to go but I just doubt it's possible.
Acrobat will happily spit out PDFs. Print as many emails as you can, and the resulting PDF file will happily load on modern machines. (PrintToPDF or abusing PostScript are free alternatives IIRC)
Still trying to get acrobat installed. This on macintosh garden are packaged in the worst possible ways for use on old Macs.
That said, I'm hoping i'll be able to essentially Select All, Print and in one single function, print out all emails as PDFs. As separate documents, not as a multiplage, 3000+ page pdf. Once I get Acrobat installed, we shall see.
Ok I managed to get Acrobat and the PDF Writer installed. Some emails print fine, others throw this error:
Trying to print all 2800 messages gives this error too. I have a feeling it's something simple like maybe there are characters in the Subjects it doesn't like. But theres no easy way (or possibly even hard way) to fix that. I'll have to poke around with it some more.
Meanwhile, I'm also open to any ideas for ways to migrate this mail data to a mail system that I could ultimately get into a modern mailbox. PDFs would suffice, but actual emails would be better.
And on that note, cc:Mail Remote 2.0 © 1992 is NOT scriptable, so there goes that thought.
Also I had downloaded ccMail 6 from that lotus FTP site referenced a few months back. But turns out the files were corrupt. And now I can't find it anywhere on there.  :-/
Ok here is the odd situation I'm in.
Lotus's FTP site does not like Fetch, but the Finder worked well enough, and I was able to get ccMail 6.1 PPC Mac. So I installed it. Of course it didn't make an enclosing folder, so it just dumped all of its files right into my Applications folder. But once I cleaned that up, I am able to open the program....
but ccMail is not a normal mail program. When you open it, the first thing it does is ask you for a login and password. There is no server. It's weird. I am able to "pick" my post office, and I can select the local files from the ccMail 2 data files. That might actually work, but here's the catch. Even though it's local mail, you still need to log in with a username and password to access it. ccMail 2 is still auto-filling the username and password from 25 years ago. I'll need to type it again fresh for ccMail 6. But I don't know it. And the customer doesn't know it. So this looks like it might be a dead end all over again. Plus it looks like this version of the app IS scriptable! If only it worked.
