KURB's World - Vintage Macs, PCs and more
I would have to probably say this is my favorite apple branded monitor i own, Multiple Scan 20. Can't go wrong with a 20" trinitron. I took a bunch of pictures with measurements for @feeef who plans to sometime in the future 3d print a replacement stand. As far as CRT monitors this is one of apple's finest ever for sure.
Another interesting monitor. In decent shape but cosmetically it has some rust on the speakers. As of now untested. Not positive what the adapter is i think its DB-15 but with audio cables. Looks nice. Thats it for the night for me off to work, again....
I read in the past some people disliked these monitors around here. I never used it. But its the first monitor from apple with a mic and speakers, and its a trinitron. So idk why.
that's the breakout adapter that allows you to use the monitor with machines that don't have the HDI-45 port... like the quadra 840 it was marketed with.
it's a perfectly nice display... as long as the plastics aren't crumbling. from what I remember it's a trinitron, basically an apple m1212 with speakers bolted on.
The plastics are perfect aside from a light yellowing, the picture makes it look worse than it actually is as i didnt use any flash and had a warm bulb on in the room.
The big issue for me is the rust on the speaker covers. I do understand the how brittle these plastics are so taking those covers off, im not sure what that requires as far as taking the monitor case apart, and thats something i really dont want to risk. Any suggestions for removing that rust and maybe repainting them or something?
It reminds me exactly of my lc 575 plastic. When I took that thing apart for the first time, the only time, to clean it, i was so very careful. And all the screw posts blew up when i put it back together. Then a little piece chipped off where the 2 sides meet. Just brutal
might be a pain to get them off. i'd use rust converter or evaporust on the metal, then sand a bit and spray coat with something that matches the colour somewhat
I think maybe ill try to give them a light scrub with something not super abrasive, maybe one of those green scrubbing pads for doing dishes and wet it and see what it does to start. And yeah try to match the paint with something like a krylon rattle can, tape off the surrounding parts with painters tape and give it a real light back and forth as to not plug the holes in the screens.
I am going to look into these rust compounds you mentioned as i have no experience with them
I have a few. The SE/30 owners guide, inside Macintosh volume 1, dead Mac scrolls, toolbox primer, ironical //c manuals. i like the designs.
Nice man. If i ever come across them i grab them right away. With all the ones i have from that picture i think i have no more than 50 bucks invested total. I am pretty happy with that. I always look out for them but you don't find them much anymore. Everyone threw them out lol
Nice monitor. $2149 in 1994 which is $4800+ in today's money. 1280x1024 @ 75hz isn't too shabby. Does it work?
I haven't hooked it up to anything yet but it functions properly while just plugged in so i suspect it will work, but i am not certain. I will test it soon enough!
Here is one of many systems I have not shown before, my IIgs woz edition. Included in the picture are my newly acquired ADB keyboard and LC 575 faceplate from my new friend @imactheknife ! I had to shuffle some stuff around to get to it so i decided to just put it all in the picture. The random hoard of sht lol. I collect retro games too, so a few of my boxes were in the vininity, i figure some people here may like some super nintendo too perhaps.
I think tomorrow ill share my IIe. I have been having problems with it. I replaced the power supply with a new reactivemicro unit and it works well, powers on. I have the duodisk and oem monitor. When powered up it gives a "double" line of "Apple IIe" on the screen. The monitor no doubt has the original rifa caps, but i believe this originates in the system itself somewhere. I am open to suggestions, and i will post pictures tomorrow. Thank you all
Another one with the cover off the IIgs woz. It is cherry and working
AppleVision are beautiful looking and sound monitors with design quirks;
- The 14" and 17" models are oversized due to speaker design compared to similar sized CRTs, the 17" is like a 21"+ on a desk!
- The 14" used a weird umbilical cable for connectivity
- The 17" was plagued with controller problems and unless replaced by Apple during the recall period probably don't work anymore
- Spindler era plastics don't help either.
But if you got one now that's working and looking good, nice find.
