So, my Performa 580CD is starting to fall apart.
The plastic is super brittle and every time I move it something else breaks off.
I feel like it's only a matter of time before whatever holds the CRT in place will break and that will be the end of the machine.
Every time my cat jumps on top of it I worry he'll break through the plastic and get hurt, but good luck stopping a cat from doing anything.
When I looked for replacement cases, they all seem to be suffering the same issue, so it's not a long term solution for an otherwise perfectly working machine.
Realistically, what are our options?
I know that brittle plastic is common to a lot of these old macs, so I can't be the only one in this boat.
I wonder if it would be possible to glue all the broken parts back into place then coat everything in some kind of strong adhesive or resin?
