10/11 pt monospaced fonts for System 6
egrath
Hi,
does anyone know if there exists a decent 10 or 11 pt monospaced font for use with System 6? The only fonts that I can find (and already have) are Monaco, Hell's Programmer and Courier, but they are just available in 9 and 12 pt.
As I'm doing some recreational programming on my Plus and my eyes are not getting better, 9 pt is too small and 12 pt is too big. So i would highly appreciate a 10 or 11 pt font.
Anyone aware of one?
With kind regards,
Egon
Scaled fonts can be a little sluggish on the older machines. That’s part of why fixed-size fonts stuck around as long as they did. I vaguely recall there was at least one (shareware?) utility back in the day that would generate a fixed-size strike based on a scalable font. Made things a lot more performant.
I'm pretty sure old versions of MacInTax used to come with one called TaxType that was monospaced. Don't quote me 100% on it being monospaced but I do remember TaxType being installed.
It's a font specifically designed for tax forms and, without looking at my most recent tax return, I'm pretty sure everything on them is monospaced.
The tool @gsteemso mentioned is called "BitFont". It allows converting any font renderable on the system to be converted to a bitmap font. So it's best to run it on a system with installed true type capabilities.
Attached are several monospace fonts (but only Courier has size 10) in a suitcase. Use Tiny Transfer or BinHex to convert back to Mac format.
BitFont is also attached.
BitFont Version 1.0 6/22/90 for MacHack '90
BitFont is a program which will create a bitmapped font from any font which can be drawn on your Macintosh. In addition to standard bitmapped fonts, it works with Adobe outline fonts when the Adobe Type Manager is installed, and also works with TrueType fonts in System 7. BitFont will also tell you how QuickDraw will draw a given font (bitmapped, ATM, or TrueType) and can create a text file describing a font and all its characters.
The fonts created by BitFont are stored in a Font/DA Mover file, and contain a single FOND resource for the font family, and an NFNT resource for the font. Using the NFNT resource type allows any style modifications that were selected in BitFont to be preserved.
The menu items in BitFont are standard, except for the items in the File menu:
Open Resource File:
This items causes the selected file to be opened, and any font resources it contains included in BitFont's Font menu. As a result, fonts can be used with BitFont which have not been installed in your system.
Show Font Info:
This shows technical information about the currently selected font as obtained from the Font Manger and the font resource. It also indicates whether the font is bitmapped, ATM, or TrueType .
Image Font:
This items causes all the characters in the font to be displayed on the screen, followed by information about bounding rectangle and maximum width BitMap computed for the font.
Create Data File:
This item creates a text file containing information about the currently selected font, followed by information for each character, including its bounding rectangle, width, and a grid showing its bit definition.
Create Bitmap Font:
This item creates a bitmapped font file using the currently selected font, point size, and style.
BitFont was written using MPW C version 3.1. It is in the public domain and may be freely distributed. Source code for BitFont is also available by contacting the author.
Peter DiCamillo
Brown University Computing and Information Services
(401) 863-7582
Internet: cmsmaint@brownvm.brown.edu
AppleLink: A0216
CompuServe: 73577,2036
America Online: PeterD11
Prodigy: FRVF15A
Thanks for finding that, guys! I was a bit embarassed that I couldn't supply any hard information, just a vague memory. Good work turning it into something concrete!
Back in 1990, I opened up ResEdit on the Courier font, and created 10 and 20 point versions of it. Why 20? Because if you've got a 20 point font and an ImageWriter II, when you print at 10 point, if you have it, it'll print the 20 point at 144dpi. I did this for London as well.
Unfortunately, I don't think I kept either of them anywhere. Bitfont sounds like a MUCH better solution. I spent hours trying to ensure 10 point glyphs lined up properly with 9 point and 12 point.
Sure, its homepage is currently
Thank you.
Unfortunately, I've tried a bunch of methods to open the .dmg or .zip file in Basilisk II (for Windows) or Infinite Mac. No luck.
Using StuffIt Expander, the .zip file does open in Basilisk II. But, then I'm left with the resource fork / data fork split into separate files.
Does anyone know how to load either the .dmg or .zip in a way that they appear in their original old Mac format?
I got dot files from that zip too, looks like the archive assumes OS X. My BBEdit 4.5.1 retail disk has the same 2.2 release which I've attached as a .sit (created in MAME).
