upgrading the ibook clamshell's L2 cache to 1MB
welp, got the new chips in and well... it still isn't passing the mac os 9 built in memory test for cache. starting to think its either address lines or firmware related. dunno if the firmware on here has ever been updated, as a matter of fact. i know for certain these chips are good.
well, tested the computer some more and it does work, but disables the L2 cache for whatever reason. maybe lack of address lines or something. gauge pro also doesn't properly see my bus overclock, and assumes the CPU is running at 266MHz with the 66MHz bus even though i had set the bus to run at 100MHz...IMG_20260614_182056.jpg
Totally not directly related, but BITD, about a year and a half after I got my DA/733/1M Superdrive model, I started getting the same error you're seeing completely out of the blue in os9, but not in osx... I ASSUME there's some kind of integrity check but i doubt there's any diagnostics for this.
Definitely interested if you can pull this off tough!
OS X definitely does the checks, and you can check in system profiler if something is amiss or has failed.
Oh definitely- I just meant that on that specific machine, i didn't even know it'd failed because OSX doesnt do the popup, and classic wasnt notifying. Anyhow.. definitely gonna be following your attempts if you plan to keep trying!
so i managed to get the RAM upgrade to 128MB working, for a total of 640MB on the system. sadly i am still stuck on the cache failing to pass the power on test, which makes the whole machine feel rather slow (powerbook 5300 much?).
turns out there is in fact an address line that likely is not connected, A16 on the 128Kx36 chips is on pin 50 although that is a no-connect on the old 64Kx36 chips... probably why the cache isn't working
Yes, they most likely didn't route all the address lines for the cache.
I know @herd has run their own address lines from under the CPU on a Pismo card before, so it's not impossible to mod the board to add them here:
