EtherTalk routing across Tailscale
ereuter
I have my home and office networks integrated with Tailscale. Each sees the other as a subnet, facilitated by having a linux machine acting as a subnet router at each location. I'm trying to figure out what would be required to bridge EtherTalk between the two networks. I would also like to integrate LocalTalk. I have a EtherPrint doing this on one network at the moment, but I assume a TashRouter might accomplish both functions? If I put a TashRouter on each network, can I tell them to talk to each other across subnets?
I assumed one LToUDP or something like that would work, but I’m not clear on whether it supports EtherTalk.
I wouldn’t want to send every Ethernet frame on the network to the other network - just the ones relevant to EtherTalk. Maybe that’s trivial, but I don’t know how to do it.
I‘d just write some Python scripts which filter out DDP / AARP frames and send them over your network. I use a central MQTT broker as a hub for exactly this purpose. If you don‘t know how to write Python scripts, any good AI model will help you.
I have enough Python experience to know that this project would make me crazy. I was hoping someone else had already sorted it out and packaged it up.
