8100 led wiring
I only have an led from a 7600. The connector is the same but it doesn’t light up when 8100 is powered on. I have two 8100 boards and same thing. Anyone with a wiring diagram for the connector?
That's the connector on the board. Pin 1 should be marked (or have a square pad).
You want the side of the LED with a slight flat on it at the lead end to be going to pin 5
Is it possibly that the connector is a bit corroded and works intermittently? This happened on my 840AV until I cleaned it up. Not aware of a contact closure on the case itself.
Hmmm, well not taking the cover off to check lol.. these covers are awful. I now have the 8100 ,8500, 840av, q800 and the 9500…love the look, but the cases are nasty to open. Especially with brittle plastics.
