8100 led wiring
I only have an led from a 7600. The connector is the same but it doesn’t light up when 8100 is powered on. I have two 8100 boards and same thing. Anyone with a wiring diagram for the connector?
That's the connector on the board. Pin 1 should be marked (or have a square pad).
You want the side of the LED with a slight flat on it at the lead end to be going to pin 5
