According to a PDF entitled 'Apple ROM Matrix', there is a listing for a ROM with checksum 852CFBDF for 'PowerBook 5300 and Assistive Technology Freestyle'
Don't got it. It's listed in the MacROMan GitHub repository but is not included in that repository's TestImages folder.According to a PDF entitled 'Apple ROM Matrix', there is a listing for a ROM with checksum 852CFBDF for 'PowerBook 5300 and Assistive Technology Freestyle'
Oddly, https://docs.google.com/spreadsheets/d/1wB2HnysPp63fezUzfgpk0JX_b7bXvmAg6-Dk7QDyKPY/ has it (which makes sense, since it and MacROMan track each other), but it includes details that imply that I had the ROM at some point to validate -- but if that were the case, it should be in TestImages.
I'm curious if the PDF is just a printout of my spreadsheet of the same name?
Ah; I had that in my "to do" list, but never got around to it. I seem to recall joevt and I both updating our MacROMan forks for that one, but I missed adding it to the sheet.FYI This list is missing the PB1400 166MHz ROM... in case you're able to request an update.
I would like a copy of that dump when you get around to it. Or maybe someone with a complete 5300 can do it.If they're not available then I'll dump mine (I don't have a complete 5300, but I do have a logic board).
PB1400 166 dump added to the sheet now. I'm also looking forward to the 5300 dump![]()
Might the 5300ce be using the 1400 ROM to support its 800x600 panel?
So it's an overclocked 5300c thenI have a 5300ce (the fancy model with the 800x600 display and 117 MHz CPU), but someone must have replaced the LCD with one from a standard 5300c before I got it, because it only displays at 640x480.
c
