Power Mac G4 MDD and the USB 2.0 chip
Dandu
I have a question: the Power Mac G4 MDDs include a USB 2.0 chip (NEC D720101F1), even though Apple marketed the machines as USB 1.1 only — possibly to highlight FireWire instead.
I have a motherboard (without anything else) that allowed me to confirm that it really is a USB 2.0 chip. But I was wondering: has anyone ever managed to actually use USB 2.0 on these machines? I found some old threads showing that third-party drivers more or less enabled USB 2.0 back in 2003, but I couldn’t find anything after that.
Did Apple ever enable USB 2.0 in Tiger or Leopard? Is it a hardware limitation? Does anyone know?
My memory may be wrong, but as I recall when they officially announced USB 2 support with the later MDDs (the FW800?) that enabled USB2 support on the original MDDs that had the correct chipset. What OS is your MDD running?
This is quite interesting. Sort of implied Apple held off on USB 2.0 support to avoid stealing Firewire’s thunder. Seems silly in hindsight.
@Durosity I thought the PowerMac G5 was the first model to support USB 2.0 officially.
NEC µPD720101 datasheet is available here.
Looks like the chip is on the underside of the board – I'm surprised having it so far away from the ports would be at all optimal.
The FW400 logic board appears to have an unpopulated BGA footprint in that location, so could likely accept a USB 2.0 chip. I don't understand why they populated it for the FW800 board if they're not using USB 2.0 since presumably the northbridge (was it still Uni-North on these?) has USB built in.
If anyone wants to try, I've attached the driver that 'CreateMac' (the Korean site that claimed they got USB 2.0 working) originally hosted, thanks to the Internet Archive.
Double clicking the image file fails with an error saying that it's corrupt on my M1 Macbook Pro. Reading some forum posts from back in 2004 some people were complaining about the same error. Maybe it can be repaired?
For what it's worth, I thought USB was in the southbridge, KeyLargo.
The image can indeed be repaired, my ADC tool works. Here's the repaired image (uncompressed HFS partition image), it contains a .pkg that installs two kexts, OMI_EHCI.kext and OMI_USBHub.kext.
Nicely done.
Looks like the same installer that's available here. I think theirs is corrupted too!
if you downgrade the BootROM on a Firewire 800 MDD to a Firewire 400 MDD, then it just sees the NEC USB 2.0 chipset as yet another generic USB 2.0 NEC PCI device on the bus and USB 2.0 speeds are enabled :)
this would imply there might be something in the device tree of the FW800 machine causing OS X to artificially not load the USB 2.0 drivers
it would be cool to see if USB 2.0 could be enabled without the need of a boot ROM downgrade
