Question about the Macintosh Portable
I did the two diode mods. Here are some photos in case one of you wants to do it. I went to the resistor because there was a steady 5v there.
Zener Diode Mod
External SCSI Mod
Also, does anyone know if I can restore the original silicone rollers on the trackball? I don't like the 12 dollar price tag on the ones on ebay.
@Sideburn
Do you remember or know what pin on the portable is 5v for the floppy drive? Can you label it? Thanks!
if I put a potentiometer on one of the speaker leads would I be able to turn the sound up and down in volume or would it just not work. Or is there a way in system 6.0.8?
I couldn't figure out where the volume controls are. Can you maybe show me where? This is technically my first mac experience so I don't know where volume controls are.
I believe in 6.0.8 you go to the Apple menu in the top left, Control Panel, and then the volume control I think is in both the General section and the Sound section, so you can adjust it from either location.
It says that I need to download their .hda to install wifi activity. How would I install the os that I want to use if they want me to use that .hda file? Wouldn't that mean that I wouldn't be able to use my .hda? I want to enable wifi activity on my portable but don't quite understand that part. Thats it. Would I be able to make my own .hda with macTCP installed then I would be able to not have to use their .hda, or is that not how it works? Thanks!
Do all the grounds on the video out need to be hooked up? For cable.
Also do I have to use all three 5v's or can I have only one?
You could probably get by with leaving some out, but it depends on how much current you are drawing. Ideally each +5V should have a GND for current return, and then the signal lines can usually share grounds. It would probably still work with just one ground as long as there's not too much current return for the wire, but it's not recommended.
