Question about the Macintosh Portable
I did the two diode mods. Here are some photos in case one of you wants to do it. I went to the resistor because there was a steady 5v there.
Zener Diode Mod
External SCSI Mod
Also, does anyone know if I can restore the original silicone rollers on the trackball? I don't like the 12 dollar price tag on the ones on ebay.
@Sideburn
Do you remember or know what pin on the portable is 5v for the floppy drive? Can you label it? Thanks!
if I put a potentiometer on one of the speaker leads would I be able to turn the sound up and down in volume or would it just not work. Or is there a way in system 6.0.8?
Do you mean in addition to the volume control in the control panel, or is that one not working?
I couldn't figure out where the volume controls are. Can you maybe show me where? This is technically my first mac experience so I don't know where volume controls are.
I believe in 6.0.8 you go to the Apple menu in the top left, Control Panel, and then the volume control I think is in both the General section and the Sound section, so you can adjust it from either location.
