Macintosh Classic revival - another battery damaged salvation
joshc
68LC040
I picked up a Classic for AU$120. Looked clean on the photos, rear ports didn't look rusted. It arrived. Battery has already wrecked it. Cool.
I immediately knew things were bad when I removed it from the packaging because I could hear rattling inside and what sounded like lots of bits of metal moving around. Things were definitely wrong when I removed one of the T15 screws on the back as it was rusted and a little hard to remove.
And sure enough...
After being somewhat rough with the rear bucket to remove it as it was so wedged closed by rust particles and presumably not opened in a long time...
Whole side of the frame rusted, fan guard completely rusted too.
I couldn't actually get the logicboard out without quite a lot of force and jamming a flat head screwdriver in a few places to force it out as it was 'welded' in there with all the rust on the frame rail.
With the logicboard out, I could do my first assessment of the damage.
Sure, it looks horrendous, but let's give it a chance...
And before we do that, let's look at the culprit of all this mess. Of course it's another red Maxell battery, dated 90-06.
OK, time to see what we can do with this logicboard.
First thing is a vinegar bath and a scrub with a toothbrush to address all the battery corrosion sitting on top of the board.
After a few minutes and a scrub:
That alone has loosened and removed a lot of the mess!
Next up was a hot wash with washing up liquid and a scrub, and then a rinse.
Which got things to this state:
A close up of the battery area after wash:
Let's look at the other side:
And a couple more close ups of the remaining damage to repair
RTC:
Battery/CPU area:
I am pretty confident that a repair of this board is worth persuing instead of immediately looking at other options.
I am mostly concerned about what's happened with inner layers, as things on the reverse don't look great.
I need to wait on supplies and some new equipment before I can start on the next stage, but thoughts and comments are welcome on what we can see so far.
Thanks for reading!
Can't wait to see it finished! It looked bad at first but with it cleaned it looks like it might actually be repairable! Have fun!
I don't want to add salt to the wound but that looks really bad. Have you even looked at the damage that the caps did to the analog board yet? The Mac Classic being prone to bad caps and exploding batteries, I would never buy one without cracking the case, showing everything inside. A Mac SE wouldn't have done all of this and it's the same specs.
I agree with mikes-macs, hopefully you can get it working again, but I have had no luck so far with mines, and they were less damaged.
The Mac SE is far more reliable, and can be repaired far more easily.
I have owned 5 or 6 of them before, including ones damaged like this before. Had varying degrees of success but yeah more failed projects than successful. Doesn’t stop me trying again.
SEs are not immune from battery damage too but yes way more reliable than Classics.
I’m not concerned about the analog board yet, need to focus on the logic board first. I know these are a pain.
Took the rest of it apart today. Analog board looks fine, actually very clean on the back.
The chassis is a mess... thankfully I bought a spare one that isn't wrecked.
Let us know if you were able to repair it.
I had 0 luck with mines, and most of the time the Analog Board and peripherals are also contaminated by the acid from the battery, so the HD and drive are all bad (more or less)
The analog board of my wife's Classic looked great, but seconds into turning the Classic on, it shut itself off. I recapped the analog board. Every aluminum electrolytic capacitor had either moisture or a pool of electrolyte underneath it. Even if the analog board looks good, these really need to be recapped, preferably before turning them on.
Yup, it will get recapped. But these usually need a little more than that, with at least OP1 and some other components needing replacement. Apple used cheap parts in these.
Spare chassis arrived, rust free:
I did some more prep of the logicboard while I wait for soldering stuff to arrive. It looks rough right now but it'll look better after its done. At least this shows that most of the traces are fine, just a few to repair. Its the vias that look troublesome.
Is that really the way to do it? I've been hesitating managing my own corroding vias because I'm finding conflicting info on how to do it.
If the via has been bathed in acid for any amount of time, it's probably the only way to do it (please let me know if anyone knows a better way!) It's dang near impossible to get solder to flow once it's been acid damaged. On Simm sockets I've had good luck scraping the top 'affected' solder off and getting the underlying solder to flow, but no such luck with via's. I use a mini drill to remove the affected solder. If any traces connecting to the via are bad, I run some wire through the via to connect to the trace. I've had good luck using this method. Wondering what conflicting data have you have seen?
Some tidbits of advice came from perplexity.ai, others from various search engine results that I did not keep track of:
"Place a wire through the via unless the board has more than two layers" (with no advice given what to do if there are, in fact, multiple layers)
"If the via has come off the board, place a wire" (which I took - perhaps mistakenly - to mean "only if the via has come off the board")
"Scrape it until shiny, if there is superficial corrosion"
"Drill it out even if corrosion is superficial, since it likely is corroded underneath"
When drilling, is the point just to break through the solder, or are you trying to remove the corroded via itself?
I've scraped these out, there's nothing there anymore, just empty holes. Advice/thoughts welcome. I assume more than a single wire is needed as it's a 4 layer board, but that's also assuming all of these vias go elsewhere inbetween...
Don't know if it's needed but I found this if you need a reloaded board. I am still hoping you can fix yours.
Yes I know about reloaded boards. Unfortunately the classic one is only available from maceffects and while I have nothing against them, I do believe the gerbers should be available but they’re not. I also don’t think I’d want to spend that level of effort on the machine. I’d prefer to wait for a spare board to come up on eBay.
This was supposed to be a quick easy project 😅
That doesn't look bad post cleaning.
You will want to drill the via out and run a strand of wire through it. It's fine to do this on multilayer boards, the goal is to clear the via, not enlarge it. I recommend these micro drill bits: https://www.amazon.com/dp/B0BWCPXYNP Get a multi-pack, you will break some of these. Also some conformal coating/overcoat/solder mask pens.
Drill it by hand with just the bit and your fingers. It doesn't take much as solder is soft and corroded solder is softer still. For patch wire, I tend to use a single strand from 26 gauge stranded wire - around 38 gauge.
Here are some pictures of a bombed quadra board I saved. Not the prettiest thing ever as I only started repairing it on a lark and wasn't expecting it to work, but you can see the methodology. Occasionally, you get lucky and can get away with just re-filling the via after cleaning the top/bottom (I recommend putting a strand of wire inside anyways) but otherwise just solder to the trace directly.
Sorry I thought there was a gerber.
Thanks @zigzagjoe
I already managed to clear the holes with a blade so not sure I need to use a drill bit. I suppose a drill bit would ensure there’s no longer any crud left in there but I also think the purpose here isn’t to fill the hole with solder it’s just to be able to pass the wire through?
