Mac G4 MDD motherboard
maccy
Hi All,
please can anyone help with identifying the power pins on the G4 MDD board, there are 2 rows of pins with Power, Reset, NMI written alongside ie 4 pins against each title but not sure which row of pins to short to start computer, reason is front panel board switch appears to be faulty, image showing pins to short would be good, thanks
I just tried on my working MDD. The results are weird. I couldn't get it to boot jumping any of the pads in any x or y direction. It's possible I have heavy oxidation (did try to scrape the pads a bit). I didn't try jumping diagonal.
Strange, (sorry btw I meant the pads not the pins) I thought these pads were similar to other mboards which have + and - usually written on them to identify which ones to jump, but not apple, the pads seem to be in a row of 2 x 2 pads with Power, Reset and NMI written against, but no indication of which ones to jump to start the machine.
Other way may be if anyone can identify which of the 10 pins on the mboard socket from the front board panel to jump to bypass the front power switch?
My MDD is acting up, so I poked at this more. These pads do work (though may be oxidized/grimy, as in my case, you should close them in the shorter direction (across the width/beam of the machine). I didn't try NMI (would be cool for macsbug reverse engineering), just power and reset. It wasn't consistent for me, but again possibly oxidization related.
I assume you folks mean these?
I've drawn yellow boxes around pairs of pads that would trigger those functions. They're pads for tactile buttons same as the Reset PMU button.
You could solder on the missing buttons for convenience.
Buuuuuut.
If your MDD is playing up, the most likely cause is the PSU as it is a very common failure mode. The solution is recapping the PSU rather than finding another power button.
As a former "MDD doctor" during their heyday, 100% this. Unfortunately this wasn't well known at the time, so we'd often get a new PSU and have the exact same problems, then swap the board, same problems, etc. ASD always passed, but the weird behaviors would continue (for instance, shutting down randomly, failing to power up consistently, etc). Some of these had symptoms of capacitor plague brand new.
However, there are a few other things to check for after you've recapped or ATX modded (personally I recommend this, but it is a chore) the PSU:
1. CPU<-->mainboard interface, especially as the heatsink applies pressure to the CPU PCB potentially bending it or leading to poor contact. This has lead to the "push on the heatsink" advice. This also worked with TiBooks with bad graphics, but I forget which corner...had one that worked fine with a clamp applied.
2. Front panel board, though I think it was usually actually the PSU being intermittent when people replaced these. It never solved issues for me, but there were a larger than normal number of people replacing these in the early 2000s.
3. Cable damage from the hinge/constant flexing
I recently picked one up and it only sometimes boots. Still diagnosing but I think it has both a bad GeForce gpu and a bad PSU. I'm not convinced these machines were ever well-designed (Apple was really pushing the thermal envelope of the case design and powerpc, and then got burned by cheap bad capacitors) but they are fast and pretty.
Adding to my list above because I just revived mine:
1. J20 RAM slot is often bad or intermittent. I am not sure if there is a performance different between two 1G sticks and 4x 512, but avoid J20 if you can.
2. ANY PCI card can mess up the entire boot process and prevent chime. This is true if they are seated badly, or if they are misbehaving.
Standard troubleshooting stuff but it can get emotional :)
Going to add "pwr/reset/nmi" 3d printed thing to my list of stuff to do on various old mac projects. I want to see if they share ground or a voltage rail, it'd be nice if I can use a single stereo audio cable for the wiring.
I wonder if the reset/nmi functionality can be added by using an iMac keyboard or an ADB keyboard with one of the USB-ADB adapters on the market. Those have the power key on them. Which is functional even on a Mac Pro (at least with the iMac 'board). Even the old Apple //e command-control-reset keystroke causes modern Macs to reboot. Works like a charm on my A1286, the times I've needed to use it.
Yes, from my limited testing, command-control-power does work with an iMac keyboard. Not sure if it works in all situations e.g. if the Mac is hard locked.
Power on from cold doesn’t work.
I didn’t try NMI.
Yeah, I've used an iMac keyboard on a Mac Mini running Mac OS 9 to bring up the mini debug window.
