LC475 with no video
I also had bad experiences on those old boards with pads being prone to lift very easily.
I wonder if it be caused by exposing the pads to too much heat.
What maximum temperature do you advise ?
when i suspected cap goo breaking connections I started reflowing pins - this chip was the first
i may have reflowed it twice ( maybe i missed one mentality )
allot of cap goo plus 2 bouts of heat did not fare out well
saying that i have had to reflow pins/pads on other boards several times without pads lifting
i put it down to sustained heat on a small pad is bad ........... sustained heat on a pad that has been 'electrolighted' is very very bad........
to them blast the whole area with a heat gun ................ ah well
there is basically zero clearance under these ram chips to run jumper wires under them , unless i start bending the pins to create more clearence
dont really want to go there
thats why im thinking of of using sticky copper tape - top left 3 pads missing , im thinking - prep the vias ( tiny sharp pin , dig out the via , file sharp point on soledring iron , flux / solder iron get good via contact - lay copper tape over the 3 missing pads and cover top half of vias - with sharp scalpal knife cut away the copper inbetween to create 3 new pads and traces - finish by soldering copper trace to via )
has anyone had any success with this method
i know i could just start running jumper wires from all over the place , including the back of the board but it be fugly
at least there are several pads that still look good , that will hold the chip solid , so the new connections wont be load bearing
imagine ...... it still gives a good chime !! , and not with just the chip removed , but the 2 caps as well !!!
SMD packages don't sit completely flush to the board. If you use #32 bare wire there should be plenty of clearance.
i was looking at a small transformer off some board i have in a drawer - the wire thats wound onto that is very fine .... and the would be insulated as well - that would be a much easier way to go shircsh
wont be going at it for a few days - have to change a blown head gasket on my car tomorrow - cant wait !!!
Regarding the onboard RAM, is this possible to disable it entirely, so that only the SIMM is used ?
Edit: this seems possible but requires a ROM modification
ive no idea - but its a great idea - ............in rom , yes i guess........... wouldnt it be great if the desigeners included a jumper to bypass the onboard ram
i wonder if there is a way to do it , to trick the rom .......... to not have to replace roms ........... some simple way to report 'onboard ram not present , but keep going ROM"
that might just reserect many lc475's
Just leave it off, don't need to do anything fancy. Desolder it.
The ROM hacks are for disabling it without removing it.
I have the onboard RAM removed from a couple of my machines. A 610 and a 650. Both which basically use a closely related Memory Controller.
