BlueSCSI does not boot Mac SE
So I have finally purchased and installed an internal BlueSCSI for my Mac SE. The BlueSCSI does not boot the Mac. I can boot it off of my external BlueSCSI and when I do the drives that are set up in the internal BlueSCSI do show up.
I swapped the SD cards around but nothing I did could get the Mac SE to boot off the BlueSCSI. I enabled debugging mode and have attached the log.
Any help would be greatly apreciated.
Your log shows:
Code:
[4961ms] DBG Waiting for USB enumeration to enter Card Reader mode.
[6061ms] DBG Waiting for USB enumeration timed out after 1000ms.
[6061ms] DBG -- Try increasing 'USBMassStorageWaitPeriod' in the bluescsi.ini
Did you try what it suggested?
Have you tried booting without an INI file? It's not really needed for normal operations for common machines like the SE.
So I increased the time to 10000 and then to 999999 but it did not work. I then deleted the ini file and it still did not work. This is my latest log file
Platform: BlueSCSI (Pico2/W)
FW Version: 2026.03.01-rel Mar 1 2026 15:12:15
Flash chip size: 4096 kB
SPDIF Mode Enabled - I2C Disabled
Reclock Pico 2/2W based boards to standardized speed
Reclocking with these settings are compatible with CD audio playback
Initial Clock set to 150MHz
Reclocking the MCU to 203MHz
Setting the SDIO clock to 41MHz
After reclocking, system reports clock set to 203MHz
=== SD Card Info ===
SD card detected, exFAT volume size: 1885 MB
SD Name: SU02G, MID: 0x03, OID: 0x53 0x44
-- WARNING: Your SD Card Speed Class is 0. Class 10 or better is recommended for best performance.
BlueSCSI CD Audio Enabled - Connect DAC to BlueSCSI or use SPDIF on I2C SCL pin
=== Global Config ===
bluescsi.ini not found, using defaults
=== Finding images ===
=== Finding images in / ===
== Opening /HD00_512 Boot-6.0.8.hda for ID:0 LUN:0
---- Configuring as disk drive
== Platform supports ROM drive up to 2848 kB
=== Configured SCSI Devices ===
ID: 0, BlockSize: 512, Type: Fixed, Quirks: Apple, Size: 40960kB
-- bluescsi.ini not found, using defaults
The SD Card Formatter is probably worth trying. Like it says on the bluescsi.com site, use the overwrite format option to really go low level.
I saw that but because the external BlueSCSI works with the SC card I dismissed it.
I will try that and see what happends
Okay, thanks for the may suggestions. I have attempted all of them. In my latest log I have found this line:
[14312ms] DBG ---- STATUS: 2 CHECK_CONDITION, sense code 0x05, asc 0x00002000
[14318ms] DBG ---- MESSAGE_IN
[14319ms] DBG ------ IN: 0x00
in my searching I have found this github thread:
It states that Data Line 2 is stuck and I probally need a new Pico.
I will do more testing but I think that I am getting closer
I wanted to give an update. I purchased the BlueSCSI from Joe's Computer Museum and after contacting Joe, I sent it back and he fixed it. Now I have a working BlueSCSI and a fully working Mac SE. Joe said that one of the connections between the Pico and the board wasn't fully soldered. I want to thank all of you for your help with this confusing issues. Also I cannot recommend Joe highly enough. He is fantastic with providing his help.
