LC475 with no video
falen6
Hi all
recently got me an LC475
battery did not leak
caps did
removed old caps and solder - scrubbed board - recapped with tants
power on gives good chime but no video display
have tried different vram pairs , tested on another machine
have tried different ram sims , also known to be good
still no video
when i add a ram simm i get bad chime , so thinking ram problem
then i pressed on first onboard ram chip next to c128 and c127 and hit the power , i get very fast chimes of death
i dont press on anything and i get good startup chime
c127 and c128 ( along with all the other caps ) leaked all over the place
the board has been thoroughly cleaned over and over with iso , acetone , ..... even boiling water !! - still no video
also - when i add ram expansion i always get chimes of death
so im thinking it is the onboard ram , bad pin / pad / trace connectivity
I have already reflowed all the onboard ram chip pins , still no video
If I have an onboard ram problem how come I am getting a good chime
also - even thought i have no video output I think the computer is crashing after the good chime as it will not boot from floppy or reboot when doing the command, option , p , r reset - nothing
i DONT have a pram battery installed ( have to get one ) but even the quick off and back on trick yields no video
im thinking of using hot air to take off the ram chips next to c127/128
just wondering if anyone has had similar issue
cheers
I never had any luck with the quick on and off, I only get video with the pram battery installed
thanks storm
i have a 3 volt dc power adapter - u rekon it would be ok to wire that into the battery holder terminals just to see ? , just to test it
i really dont want to blow this up !!!!
also - i have tested the power , even swapped out the psu from my working lcIII , thats where i swapped the simms just to see
they all come up good
ive ordered up a few of those 'macbatt' things
i had a 475 before and the quick on/off/on always worked for me as well
who knows
maybe its part of the startup sequence , that if the video is not initilized the start up freezes
From my experience a battery is required in order to get video display.
Ditto on the battery with this model. And I have much better luck since I started using a white vinegar soak to eliminate the cap juice (followed by DI water and 99% alcohol) for what its worth.
well , just tried it with a 3 volt battery and still no video
good chime
no video
does not try boot from good floppy in a good floppy drive
it appears to chime and then just freeze
as i said before , i got this , battery removed , no sign of any acid damage , caps leaked but no bad signs of the usual corrosion from electrolite
its even chiming now with the ram extension installed - im using 2 good vram simms
but no video
have not seen a video display on this since i started working on it
ill try the vinegar both sides , see if that helps
has to be something stupid !!!
