    We've also made some quality of life improvements to the Trading Post. More info here.
The "820-0961-A" mystery G3 3.3V FlashRom
It looks like it is, but I can’t see any new features or behaviour having run it for a little while in my G3.
ChatGPT says:
This line sets the cache line size for PCI-PCI bridges during configuration. It was likely added in Rev D to ensure proper initialization, enhance performance, or fix compatibility issues with specific devices.
A user of a rev C ROM Beige G3 reports that applying the cache line size and master latency timer fix that exists in the rev D ROM for PCI bridges improves performance.
You can test this on a Beige G3 or any Power Mac.
First, find the config address of the PCI bridge that contains the controllers (SATA, USB, FireWire, etc.) that you want to test/improve.
Code:
dev pci/pci-bridge
.properties
Result:
Code:
reg                     00006000 00000000 00000000  00000000 00000000
Look at the reg property. You want the non-zero address that ends in 00 which in the above example is 6000.
Now go to the PCI host device that is the parent of the PCI bridge to read the PCI config registers. Offset 0 is the device and vendor IDs. offset 0xC is the cache line size and the master latency timer.
Code:
dev pci
\ get the vendor and device IDs and verify that they match those of the PCI bridge.
6000 config-l@ 8 u.r
\ get the cache line size and the master latency timer.
600c config-l@ 8 u.r
Result:
Code:
00012008
In this example, the cache line size is 0x08 and the master latency timer is 0x20. 0x01 is the PCI header type (0x01 = PCI bridge).
To change the cache line size and the master latency timer, use this:
Code:
0000 600c config-l! \ set cache line size and master latency timer to 0.
or this:
Code:
2008 600c config-l! \ set cache line size to 32 and master latency timer to 8.
Then continue booting into Mac OS and run some benchmarks. You'll want to run benchmarks for 0000 and 2008. I wonder if other values can be used?
Could it have possibly been a fix for the Rev C incompatibility with the Sonnet Tango Trio?
Probably not. I did find an issue with PCI controllers that don't have a PCI Option ROM with Open Firmware fcode (USB and FireWire controllers). I made a patch to fix this which I added to the ROM extender that I mentioned at
https://68kmla.org/bb/threads/mathey-msata-13umac-ide-sata-card.47740/page-5#post-578415
I've attached the updated version. The source directory has a list of patches. The one discussed here are:
create-defaults patches.of
pci-pci-config-patches.of
Good to know. I only have one multifunction card, a USB 2.0/Firewire, it has a bridge chip on it. It would be easy for me to benchmark throughput as I can just swap out the ROMs between reboots.
I had unsoldered the chips and scanned them in by using a chip-programmer. I had to clean the chip-legs to get a good contact. Maybe something went wrong at some point?
Necroing this thread a bit.
When you folks were combining the chip contents into a full ROM dump, did you swap every pair of bytes?
The chips are 16 bits (2 bytes wide). A ROM dump from the machine interleaves the four chips, taking two bytes at a time from each chip, but.....
the ROM dump from the machine has each pair of bytes swapped in order from how they are stored on the chips.
So, if you had:
(read from chips on chip reader)
Chip 1: ABAB ABAB ABAB ABAB
Chip 2: CDCD CDCD CDCD CDCD
Chip 3: EFEF EFEF EFEF EFEF
Chip 4: FAFA FAFA FAFA FAFA
When read directly from the machine (with ROM dumping utility), the corresponding addresses would show:
BADC FEAF BADC FEAF BADC FEAF BADC FEAF BADC FEAF BADC FEAF BADC FEAF BADC FEAF BADC FEAF
BTW, do not install these modules in anything but a Beige G3. They're pinned to take power from 3.3V. They'll fit in the X100, X500/X600, ANS and PowerExpress machines, but all of those power their ROMs with 5V. Best result is they just won't do anything, won't power up, because the 3.3V pins aren't powered in those machines' ROM slots (I hope).
There is someone on eBay right now who sells original Apple PPC 4Mb 3.3V Flash ROMs. The seller had about 100 of these Roms. The origins are unknown. I have bought 10 of them to experiment.
Now on to the real reason I hunted down this thread.
I bought one of these in late 2024. I can't find the darned thing. Can I please get someone to check the resistance between...
Never mind. Typing that out seems to have triggered a memory. Found the thing on top of my Beige G3. Duh. Two many boxes of snips and snails distracted me as possible hiding places.
What are you checking?
How the WE_ pins are wired. I know where they are on the chips and on the DIMM edge. Are the connected? Or do they run through some of those blank resistor positions on the board? Are the chip WE_ tied high? If so, how high (with what resistance)?
The chips must be held high during operation (reads) or they wouldn't work. Does the DIMM do that, or does it rely on the host machine to supply HIGH on the WE_ pins of the DIMM?
Wouldn't the G3 DIMMs be wired similar to PowerSurge DIMMs (except the voltage source)? Schematics at:
https://bitsavers.org/pdf/apple/powerpc/PowerSurge/ROM_Flasher/
G3 and PowerSurge/TNT/8600 schematics are at:
https://www.macdat.net/repair/apple_schematics.html
Both G3 and PowerSurge have a programmable write enable bit which allows the ROM DIMMs to be flashed while running Mac OS so the WE signal is probably not wired high or low. The signal probably just comes directly from the chip that has the write enable bit - HammerHead for PowerSurge (TNT) and MPC106 Grackle for Beige G3 (Gossamer). The B&W G3 firmware updater has Open Firmware Forth code that shows how to enable flashing for MPC106. The Apple Flasher Utility has PPC assembly that shows how to enable flashing for various Mac models or memory controllers:
Code:
read 'XCOF' (128) ":Objects:xcoffResources:CopyToFlashPDM.xcoff";
read 'XCOF' (129) ":Objects:xcoffResources:CopyToFlashTNT.xcoff";
read 'XCOF' (130) ":Objects:xcoffResources:CopyToFlashCAT.xcoff";
read 'XCOF' (131) ":Objects:xcoffResources:CopyToFlashPBX.xcoff";
read 'XCOF' (132) ":Objects:xcoffResources:CopyToFlashM2.xcoff";
read 'XCOF' (133) ":Objects:xcoffResources:CopyToFlashPSX.xcoff";
read 'XCOF' (134) ":Objects:xcoffResources:CopyToFlashTanzania.xcoff";
read 'XCOF' (135) ":Objects:xcoffResources:CopyToFlashOpus.xcoff";
read 'XCOF' (136) ":Objects:xcoffResources:CopyToFlashGossamer.xcoff";
read 'XCOF' (137) ":Objects:xcoffResources:CopyToFlashPEx.xcoff";
I'll take a look at those schematics. That is another route to the information that I want. Thankyou. It sounds like WE_ is just wired from chips to DIMM pin and then the chips rely on the motherboard to provide the proper WE_ level. But I did not want to assume that. It is entirely possible that the DIMM is meant to pull WE_ on the chips slightly high (through large value resistor) and that during Write operation the motherboard would drag it low by asserting a stronger (less resistance to GND) Low signal.
What are you interested in doing? Or what’s the info for?
Working on a programmable DIMM. I did a Read-only DIMM (program chips before soldering) 20 years ago. The bright software folks seem to have a need for a programmable DIMM in this format now, so I'm adapting the design. But there are details.
For example, 820-0961 DIMM from the beginning of this thread does not have the RY/BY# pins from the chips connected to the DIMM edge connector. They're kind of necessary for chip programming, although I guess one could program them blindly and trust to timing.
The DIMM runs them to a resistor pad the other side of which (if populated) would connect to pin 121. This is problematical, because on the 5V (PowerSurge) version, pin 121 is a 5V source pin. On the other hand, pin 120 is Vcc on the 3.3 (Beige) version, but NC on the PowerSurge. So RY/BY# could be connected to pin 120 on PowerSurge. That's kind of inelegant.
Looking through my collection for a 5V reprogrammable DIMM, but if it used EPROM or EEPROM instead of Flash, it may not even have a RY/BY# pin.
Messy.
Also found that CE_ of the Flash chips on the 820-0961 module are floating, not tied low, not connected to a DIMM pad. They're routed to an unpopulated resistor that would go to pin 35, which is not GND, but is something called RCST# on the schematic.
https://www.macdat.net/files/pdf/apple/schematics/apple/powermac_g3_gossamer.pdf
The FlashRom CE line is on pin 12 of the chip. These pins go to contact 115 on the Rom-socket (through a 0-Ohm R1), which is RCS0 (rom select 0). A resistor (R2) can be changed so that RCS1 (rom select 1) is connected (contact 35 on the socket). Both select lines go to the Grackle.
R7 (unpopulated) connects the RY/BY# pin to contact 116 (Flash detect) which does not seem to be connected to anything on the Rom-socket. R8 (populated) connects the RY/BY# signal of the Flash-chips to contact 122 (BurstCap_). RY/BY# is also connected to a capacitor against ground.
The RY/BY# signal can be accessed by selecting "rom-select 1" and data bit 33 (read-only). The capacitor is strange there. Maybe it has something to do with timing? It may basically be a kind of sample and hold circuit. At least it would be if the state of RY/BY# becomes high-z during the programming cycle and the state would be readable without accessing the Rom.
It would be nice if the flash ROM had a switch to enable built-in ROM in case the flash ROM has a bug and needs to be reflashed. While in Open Firmware, the switch can be changed to expose the flash ROM for flashing.
Would it be possible to have a jumper or something on the flash ROM so that it appears as 4 MB at FF800000 instead of 4 MB at FFC00000 so that both ROMs can work at the same time? Then one can boot with the normal ROM to flash the flash ROM. This way, the switch doesn't need to be changed while the power is on to do a flash.
Thank you. I see the CE_ connection now and it makes a kind of sense for there to be alternate resistors to RCS0 and RCS1, although looking at the G3 schematic, it kind of looks like they're using RCS1 for some kind of mutant OE/CE enabler on those two switches/buffers to drive some Data Bus pins with ?hardware sense? data?. Should know better than to try to get familiar with a schematic after Midnight...
This is rather problematical for a "Universal" firmware module, though, as the PM9600 shows DIMM 35/115 as NCs as does the PM8100. In practice, there doesn't seem to be any problem with just tying the chip CE_ pins low and not connecting them to the DIMM edge at all.
Apparently, the MPC106 can address two sets of 8MB ROM, depending on RCS0 and RCS1. I wonder if there is any provision for using that feature in the Mac software. It seems likely that the 8 MB of address space associated with RCS1 just never gets used in Apple's implementation.
Still looking at RCS1, I don't think it should be connected to the ROM DIMM at all, although it clearly is in the diagram. It's active low, so it would have to be held high while the RCS0 portion of the ROM is being used. But if RCS1 is high, then it goes through those inverters on the inputs of U9 and U10, becomes a Low signal, and then activates OE_ on U9 and U10, thus driving what looks like hardware sense data onto CPU Bus Data pins 32 - 47.
Maybe I'm completely wrong about how RCS0 and RCS1 work....
I see RY/BY_ connected to R4, not R7. R7 does terminate at DIMM 116. The other end of R7 appears to be straight to Vcc. This makes sense as DIMM 116 is used to shut down the motherboard ROMs (none on the G3) by being routed to motherboard ROM CE_ pins.
Also, I'm seeing R8 tying DIMM 122 to Vcc, which makes a kind of sense, because if it is Grounded, the Beige won't see more than 512 MB of RAM for some reason. I guess the signal "BurstCap" has that effect somehow. "Cap" = cap as in lid or top? Or "Cap" = Capacity?
Chip Pin 1 is RY/BY. I think you accidentally got Chip Pin 23, which is Vcc when you traced connections to R7/R8. Willing to find I'm wrong. It's easy (for me) to get confused with the finicky details.
Is there some way to tell the host machine which of those two addresses to use? The problem, that I see, is that the host machine expects the ROM to be at a certain address, and when it is programming the ROM, it's going to use those same addresses. Or do you get to choose the address range to which it programs?
Could “BurstCap” be short for “burst capability”?
It could be, but why would tying it low reduce the total amount of RAM that the machine will address? I could see it affecting performance, but capacity? Unless turning on bursts eats an address line, or something.
