Imac G3 DV CPU SWAP (just a few steps away)
indibil
Good evening everyone!
I've been working on this for the past week. I know it's nothing groundbreaking, it's not the first time it's been done, but I'm going to document everything I've done and discovered, and in the end, I need your help to finish it.
I have an iMac G3 DV 400MHz, and I had a spare motherboard. Although they're hard to find, I was able to locate a G4 DA 533MHz processor.The original G3 processor is running at 2.05V, and the new processor, an XPC7410RX533PD, has a nominal Vcore of 2.0V, although it can run up to 2.1V.
It wouldn't have been necessary to reduce the voltage, but I decided to see how it could be done. I was discussing it with @herd; the integrated circuit responsible for managing the Vcore was the CS5158.
The voltage should be managed by Vid0-4, but it wasn't. I have a faulty 350 motherboard, and I've desoldered CS5158. None of the pads for Vid0-Vid3 are connected to anything, and Vid4 is connected directly to ground.
Vid0-3 were not connected to anything (logic 1 according to the datasheet) but Vid4 was connected to GND (logic 0), so the voltage should be 1.3V. So something must have been forcing the Vcore to rise to 2.05V, when @herd suggested to me that there might be a voltage divider in VFB.
On the 400MHz motherboard, R225 is in parallel with R89 connected to Vcore, and R88 to GND, creating a voltage divider on VFB. But if you look at the first picture of the 350MHz motherboard, R225 isn't there. So perhaps the 350MHz motherboard has a different voltage, but I can't measure it; it's faulty.
I kept R225 (660 ohm) and changed R89 from 4.9kΩ to 2.2kΩ, and the Vcore dropped to 1.95V. Although I finally opted for 2.7kΩ and got 2V.
I forgot to take a picture with the new CPU, but after adjusting the voltage, I swapped the G3 processor for the XPC7410 and also changed the two cache chips from the iMac (2x 256kB) for those from the G4 533 (2x 512kB).
And I adjusted the speed to 600MHz. I couldn't get it past the "chime" at 650MHz, maybe with more Vcore, but for now it's fine as is. If you look at the photo, on the left in C115, I'm keeping the original R89.
At this point, as you'll see in the photos, there are two setbacks. The first is that it only recognizes 512kB of L2 cache, due to the firmware configuration, and the second is that the ratio is also fixed at 2.5:1 (5:2), meaning we're not using the maximum speed of the cache chips (275MHz chips capable of running at 300MHz).
First, I needed to verify that the 1MB of cache was available and also that the speed was capable of running at 300MHz. For the speed, in CPU Director, under OS9, I was able to configure the ratio to 2:1, and it works perfectly.
To verify that the 1MB was available (there was a possibility that Apple had not routed the necessary tracks to be recognized) I had to use some temporary "tricks" that a colleague told me about, under OS X Tiger.
Everything seems to be working correctly. Here comes the difficult part, and where I'm stuck. I admit my limitations; I can manage by swapping chips, but working with and manipulating OpenFirmware isn't my strong suit. I've always used third-party patchers, but there isn't one for this iMac that can set a 2:1 ratio in the firmware and also change the cache size from 512kB to 1MB.
Following @joevt 's instructions (from this), I was able to download the complete iMac firmware, which I've attached along with the PDF that explains how to configure the CPU parameters, which I also find difficult to decipher. I had done this with the small EEPROMs that accompany the PM G4 processors; there I was able to locate the ratio and size configuration, but this file is very large and I don't even know where to start.
Perhaps this point is the ratio? Would the red circle represent the ratio? But if it were, I can't locate which parameter is the cache size.
I've been told that I could modify the iMac's Firmware Updater to make these changes, but I need help. First, I need to locate the values I need to change, then correct the checksum (I've only done this with Sega Megadrive ROMs using a specific tool; I don't even know how to calculate it), and finally, modify the Firmware Updater to run it.
I know it could go wrong, but as a last resort, I have a TL866 and this adapter.
Before I finish, I want to give a HUGE thank you to @herd and @joevt for their help and patience in guiding this project, which I hope can help many people make this modification.
Yes, that's the ratio. The document you posted makes this pretty clear. My suggestion would be to convert that document into a utility (a bash or perl script or Hex Fiend.app template) that parses the config block in order to understand your config block.
The config block starts at 0x3F00, as you've hilited, in the ROM dump.
"Table 1. Sys-Config (Boot ROM System Configuration )" in the "Boot Flash System Configuration Block Version 2.5.15" document says "Processor Info (Table 5)" begins at offset 0x24.
"Table 5. Processor Info" says "Level 2 Cache Section" starts at offset 0x1C.
0x3F00 + 0x24 + 0x1C = 0x3F40
The bytes you have at that location say the following:
0x3F40: # of L2s : 0x01 ; (what would two L2 caches mean?)
0x3F41: Size of L2 : 0x13 ; 19 decimal; 2^19 = 512K
0x3F42: L2 Bus Width : 0x06: 2^6 = 64 bit.
0x3F43: L2/Processor Ratio : 0x52 = 5:2 according to Table 5.2.
0x3F44: L2 Mode : 0x01 = no parity, not write thru, 0.5 ns L2 Output Hold, Pipelined Burst
0x3F45..0x3F47 : Reserved : 0xFF 0xFF 0xFF
I've attached dumps from your iMac ROM dump.
The first 0x80 bytes (0x3F00..0x3F7F) of the Config Block in your ROM matches another iMac (PowerMac2,1) with the same firmware version. All such iMacs should have the same first 0x80 bytes. The second 0x80 bytes (0x3F80..0x3FFF) contains info specific to your iMac. Other differences exist in NVRAM. Everything else is the same.
Your iMac has firmware 4.1.9f1. You posted info extracted from the 4.1.9f1 firmware updater. A firmware updater includes Config Blocks for many Macs. The Config Block for your model is dumped in the "configblock 0x0081.00 Kihei.txt" file. Therefore, we just need to change the bytes in the config block in the firmware updater. What bytes do you want to change? The size and ratio? I've attach a firmware updater with the changes. Put the firmware updater on a disk and load the firmware updater in Open Firmware (after booting the Mac into programmer mode).
It may help to boot into Open Firmware and do setenv auto-boot? false so that it automatically boots into Open Firmware. Then you can boot the Mac into programmer mode and get into Open Firmware more easily. While you're there, connect using telnet from another Mac or PC and capture the output of dump-device-tree before applying the firmware update.
Download the 4.1.9 firmware updater and follow the instructions to get into Programmer mode (but don't run that installer).
https://forums.macrumors.com/threads/powerpc-mac-firmware-boot-rom-updates.2285855/
After the firmware is applied and you restart, capture dump-device-tree again so we can compare.
Use the dir command in Open Firmware to find the patched firmware updater file (it may be easier to remove spaces from the firmware updater file name). You should know the partition number (in decimal). Use diskutil in Mac OS X to find that.
Okay, that's very helpful. Thank you.
You're able to understand all this with great ease; I can barely grasp it. I'm rereading it; I admire you.
Just a quick note: this part: 0x3F40: # of L2s : 0x01 ; (what would two L2 caches mean?) -> could it indicate that there are two L2 cache chips? I can't think of anything else.
I understand that the file "ROM 4.1.9f1 iMac G3 (Slot loading) Firmware Update patched.zip" includes the modified update you performed, is that correct? Thank you for changing the ratio to 2:1 and enabling 1MB.
I've only run patchers the "normal" way: run the patcher in OS9 or OSX, restart by pressing the "program" button, and once you hear the beeps, release the button and wait for it to complete. :)
In this case, I understand that I need to run commands in Open Firmware. Is that correct?
Regarding connecting with Telnet, I tried it once but couldn't get it to work. Is there a thread that explains it simply?
"iMac Firmware Patched" is the firmware updater. If you open it in a text editor, you see that it starts with some Open Firmware code.
Code:
\ Copyright: (c) 1998-2001 by Apple Computer, Inc., all rights reserved.
\ 000419F1 20010914
hex
device-end 0 to my-self
The first line is an Open Firmware comment. The load command in Open Firmware assumes that any file that begins with \ contains Open Firmware Forth code. The load command can load other file types (bootinfo (tbxi), xcoff, pe, elf, pef, etc.) (depending on the Open Firmware version) which are usually boot loaders for OS's.
For connecting with telnet, go to the first post here, search for telnet, and click on all the links. I think the first one #54 is most relevant.
https://forums.macrumors.com/thread...l-work-in-a-beige-power-macintosh-g3.2303689/
telet has existed in Open Firmware since 3.2.4f1
After connecting with telnet, the first command you should do is:
dev / ls unselect-dev " devalias" evaluate " printenv" evaluate dump-device-tree words
as described in that post in the "Troubleshooting" section.
After restarting from the firmware update, just do the dump-device-tree part.
The next command you should do is the dir command. I think you can google "How to use the Open Firmware dir command" and get some relevant info. You should know the partition number so that you can include it in the device path for your disk.
Go here:
https://developer.apple.com/library/archive/navigation/#section=Platforms&topic=macOS
Enter Open Firmware in the search field.
Near the top is a document named "Running files from a hard drive in Open Firmware".
Code:
\ 000419F1 20010914
hex
Go here:
This is the output before the update. Did I do it right? I used a Linux PC; I don't have a modern Mac, and I saved the terminal text as a .txt file.
I haven't updated yet; I need to figure out how to run the installer from that link. Otherwise, I'll try desoldering, programming, and soldering.
Code:
\ 000419F1 20010914
hex
Go here:
You made me sweat!!! :)
Plus, add to that how complicated it is to type Open Firmware commands with a Spanish keyboard layout, hahaha, it was hard to find the ":" and the "\" key.
I've attached what I got from teltet, before and after; I hope I did it right.
I've attached photos of the whole process.
On a separate note, for the last few boot cycles (even before the update), some lines appear during startup, and inside Open Firmware, I see ghost characters in orange. Could this be a hardware failure? Or an incompatible resolution? Once booted, OS9 looks perfect, and OSX only shows a short vertical line next to the cursor, which looks like a driver problem.
Thank you so much @joevt and @herd for your help!!
I've added some Geekbench results under Sorbet Leopard. These are for illustrative purposes only.
G4 600MHz - 512kb L2 cache - 5:2 cache ratio
G4 600MHz - forced 1MB L2 cache - 5:2 cache ratio
G4 600MHz - patched 1MB L2 cache - 2:1 cache ratio
One way to tell if you did it right is to open the file that you created and compare its contents to what you saw when you did the command. In this case, it seems that only part of the output was saved. You need to increase the terminal scroll back buffer in your Linux app. In macOS, I use Serial.app and set the scrollback rows to the max 1,215,752,191 lines.
I though load was the command to use but you used boot which also works. The boot command does a load command followed by a go command.
I suppose those keys are easier to find if using telnet?
I'm not sure if the firmware updater can be run from telnet? It looks like the firmware updater has code to open the screen device to show the flashing progress bar so maybe it can work from telnet.
Nope. But you can try again to get the after info at least.
Looks like a problem with the GPU driver in Open Firmware setting up the VRAM. What GPU are you using? Is it an original Mac version or is it a flashed PC version?
Do you have a picture of the Mac OS X cursor problem?
Did the lines appear before modifying the L2 cache?
Have you run a memory test? Apple Hardware Test?
Congrats!
This is an iMac so the GPU is probably the original.
Grab the iMac firmware from Mac OS X and we can compare to make sure the firmware updater flashed it correctly. It's probably fine since it has checksums.
Hi, yes, as you say, it's an iMac, and I'm using the original Rage Pro. The graphics problem appeared before the patcher, as you can see, it already happens in OpenFirmware before running the command. It appeared after changing the CPU and cache chips, but not immediately. That's the strange thing. It first appeared when booting Tiger but not with Sorbet, but on the next boot it appeared with both.
I tried to run Hardware Test but the CD I have is for Power Mac and it won't let me run it, but under OS9 I've tried some games, and I think it might be some damaged VRAM or a cold solder joint.
I have a 4.7.1f1 firmware updater that might work with your iMac. It's the latest 32-bit firmware updater that I have. It has config blocks for 66 different Mac models. Your iMac has prod-id:0x0081.00 which is renamed from "Kihei" to "P7".
Versions of the firmware updater since 4.5.5d2 have Open Firmware drivers and ndrvs separate from the main part which means each model can pick and choose what drivers to include in their firmware (because all drivers cannot fit).
This is the info and driver list for prod-id:0x0081.00:
Code:
    20) pos:0x000e2a64 offset:0x000000a0 prod-id:0x0081.00 configchechsum:0xf88e2d56 version:471f1 date:2003-09-04 checksum:0x9bb730d2 √ name:P7
        20) pos:0x000e4a84 run() add(2,5,6,30,32,38,41,42)
     2) pos:0x000e5cac offset:0x000003ac checksum:0xd8024a2c √ actual:0x00000421 (3 extra bytes)   name:scc
     5) pos:0x000e70fc offset:0x00000c2c checksum:0xe035c068 √ actual:0x00000fa8                   name:DEC21143
     6) pos:0x000e7d28 offset:0x000010fc checksum:0xdc590ec6 √ actual:0x00001922                   name:heathrow-ide
    30) pos:0x000ee244 offset:0x000025ec checksum:0xc3d843d2 √ actual:0x00003baf                   name:usb-openhci
    32) pos:0x000f178c offset:0x00003978 checksum:0xce10e0db √ actual:0x00005586                   name:firewire-OHCI
    38) pos:0x000f989c offset:0x000000bc checksum:0xbb554320 √ actual:0x000000a3 (3 extra bytes)   name:UNI-N-AGP
    41) pos:0x00104444 offset:0x0000192c checksum:0xac90feba √ actual:0x000027b8                   name:ATI-iMac2-128k100
    42) pos:0x00105d70 offset:0x00006cbc checksum:0xf5eb70dd √ actual:0x0000e348                   name:ATI-iMac2-128K100-ndrv
The ATI-iMac2-128k100 drivers appear to be identical to the ones in the 4.1.9f1 firmware updater.
4.7.1f1 adds support for booting from SATA, but I don't think that's useful for an iMac which doesn't have PCI slots and their exists SATA to IDE adapters. 4.7.1f1 may have other interesting changes though.
Code:
        BAR   BAR   Boot   Boot   Boot   Boot   Boot   Sound
    Mac                                         OF version                             ATY,Fcode versions                                                mem   I/O   FW     USB    SATA   SCSI-X GPT    Arch             Notes
√   Firmware Updater 4.1.9f1                    OpenFirmware 3                         1.69, 1.69, 1.73, 1.77, 1.77                                      4-1C  1C-2  Yes    Yes    No     No     No     0x0e+0x12        *                  4.1.9f1    BootROM built on 09/14/01 at 13:18:04
√   Firmware Updater 4.7.1f1                    OpenFirmware 3                         1.69, 1.69, 1.73, 1.77, 1.82, 1.83, 1.87, 1.86, 1.90, 1.88, 1.90  4-1C  1C-2  Yes    Yes    Yes    No     No                      *                  4.7.1f1    BootROM built on 09/04/03 at 13:39:26
The firmware updater I attached has a menu and some debug logging.
Enable the debug logging using this command before running the firmware update:
Code:
1 value aapl,debug-ofz
I think you should use the fall option from the menu since the format of these later firmwares is different.
Try using telnet to do the firmware update so you can capture the log of what's happening.
But first, use telnet to capture the result of this command:
Code:
make sure the file includes everything - it should begin with the command you entered to produce the results.
Do the same command after performing the firmware update and doing a restart.
The original debug firmware updater is "Core2001.4.7.1f1.ofz"
The patched debug firmware updater is "Core2001.4.7.1f1.patched.ofz" (iMac "P7" L2 cache size 1MB, ratio 2:1)
Warning: I don't know if Apple ever tested this later firmware version with your iMac model. So if the Mac can't boot, then you'll need to restore your firmware from a backup by removing the flash chip and programming it externally.
Code:
Code:
Code:
Code:
Hi!
Before seeing your reply, I managed to repair the iMac. It seems it was some cold solder joints on the VRAM chips. I reflowed them with flux and a soldering iron, and now I don't have those artifacts anymore.
Now that the iMac is working, I'm a little hesitant to try this new firmware, in case it's not compatible and I have to remove and reinstall the EPROM.
If you're interested in trying the new firmware, I can try to find another iMac motherboard on eBay or a similar site and test it for you.
Out of curiosity, what improvements might this new firmware offer? If I find another motherboard and it works, I could then apply it to this one, once I'm sure it's working.
I would have to compare the Part1.txt and Part2.of files of 4.1.9f1 and 4.7.1f1 to find all the differences, which you probably don't care about, such as adding support for vectors , 16-bit fcode numbers, booting from sata, etc. It's just Open Firmware stuff that mostly has nothing to do with OS 9 and OS X.
I think I've done the full dump via telnet this time; I've attached it, I have configured "unlimited scrollback". It's a shame I didn't do it properly before updating. Is it useful for comparing with the initial dump I made of the iMac G3 firmware?
A question for you and also for @herd. If a herd interposer were used to install an MC744x on this iMac G3 with a BGA compatible with MPC7400/7410, since the MC744x has the L2 cache integrated into the processor (1:1 ratio), would the firmware also need to be modified to clear the L2 cache configuration, as happens with Power Mac updates for MC744x processors where there isn't a small EEPROM with the cache configuration? I gather that if it's not cleared, the cache would be inoperative because it would try to configure 512KB and a 5:2 ratio at startup.
@herd, would you be willing to try your interposers on one of these? If you have one, of course. The Newertech patcher for MC7447/8 works on these G3 slot iMacs; I tested it and it worked. But I removed it before making my modification, just in case...
That output appears to be good.
Only complaint is your input command line was truncated at 80 columns width, but I think that's ok since everything else was not truncated.
One improvement might be to do setenv fcode-debug? true and restart before doing the commands. But it appears that fcode-debug? doesn't have the affect in 4.1.9f1 that it has in 4.2.5f1 and later which is related to the visibility of words that are created with headers instead of external.
For example, the word >q.next@ is created with headers. The output from words in 4.1.9f1 includes that word, but in later versions of Open Firmware, that word would be hidden unless fcode-debug? is true.
Your initial dump didn't include output from dump-device-tree did it? The only thing that would differ would be the L2 cache info.
Wouldn't we want to change the config block so that HWInit configures the L2 cache of the MC744x correctly just as we did for your 7410? Or is the setup of the L2 cache done by new code added by the The Newertech patcher? L3 cache? https://68kmla.org/bb/threads/ppc750gx-vs-ppc750gl.39043/post-558832
Thank you for posting about your project and congratulations on its success! It is interesting to read about and I hope it will inspire others. I'm sure that CPU is noticeably faster. In theory either a 7447 or 750G should also work in there at modest power levels, but these would be even more work. Having the CPU and firmware soldered to the same board also means testing can become very time consuming and there is usually a limit to the number of times you can heat cycle the related components.
