Macintosh Plus analog board issue
You may need to put a different heat sink on it as it is reversed. There looks to be plenty of stock of these worldwide which is good.
Voltage probably too high and security kicking in.
You have got the chime… try lowering down the voltage (on the side you have got a potentiometer to do so)
Welp, the other day I got a new analog board. Recapped the three RIFAs, the seller said it was taken from a working mac, and guess what? It still has the same issue! I really have no idea.... could it be a CRT issue? Maybe the CRT has weird current draws or has issues, I don't know. Really stuck!
It’s pretty much a given that since you’ve swapped the analog board and the symptoms haven't changed at all, the trouble is likely living on the logic board. You can definitely stop worrying about those RIFAs for now. They’re just there to filter RF noise on the AC lines and won't actually stop the machine from booting or cause logic issues.
The great news is that you're getting a boot chime! That’s a huge win because it means your CPU is alive, running code, and successfully talking to the ROMs. Since we can probably rule out the analog board, here’s where I’d focus your energy on the logic board to stop that chime loop.
One fairly common cause of a boot chime loop is the reset circuitry.
Since you're testing without the case, we know the plastic buttons (the Reset and Programmer switches) aren't physically stuck, but the circuit itself could still be latching low. On the Mac Plus, the Reset and Interrupt lines are 'open collector,' meaning multiple components can pull them to ground to trigger a restart.
Even without the external switch, the physical push-buttons on the board can internally short or get gunked up with debris, making them trigger with the slightest vibration.
It’s worth checking the continuity on those switches or using a logic probe to see if the HALT or RESET pins on the 68000 are pulsing low when they shouldn't be. If a buffer chip in that path has failed, it might be holding the CPU in a permanent reboot cycle.
Another common cause of boot chime loops in this machine is the RAM SIMM configuration or the RAM itself (assuming, of course, that your DC voltages are within acceptable tolerances.)
Also, have you reflowed the solder joints on the J1 connector on your logic board and analog board? You would be surprised how often cracked joints on J1 produce all sorts of issues in this machine. If you haven't done so yet, could you post a close-up picture of those joints?
Don't give up! You are almost there. it seems you have no more issues with the circuitry of your AB, and that is a big thing!
I just checked the continuity, and both of the switches work as intended, nothing when the switch is not pressed.
Well last time this thing worked the RAM wasn't a problem... I also tried reseating it and cleaning the connectors both on MB and RAM, and nothing changed.
Haven't reflowed it... I guess the joints look kind of cold- soldering is not my strong point, all my experience comes from soldering some floppy drives and this macintosh... 🫠
Can you try monitoring voltages ? You should know what you are dealing with.
I monitored the 12v and 5v voltages using the floppy port method and, I'm honestly quite afraid of the results
Even when the knob on the AB is set to minimum voltage, the 12V ranges from 11 with a couple of spikes to 14 and 5V was from 4 to 6, almost 7 volts. Now, I'm unsure about this since It's kind of hard getting decent measurements with the mac constantly boot looping, so, the results might be off
I attach the images I took of J1 (even on the logic b.) ((i never know)), and of the entire logic board
If you need me to take pictures of certain joints or components ask away, anything is welcome
The solder joints on your J1 connector (4 pins) on the AB look quite bad; some cracks are even visible. You also need to check the solder joints highlighted in the attached picture.
You're right, those at j1 look like cold solder joints.
The voltage spikes you are seeing are likely due to the machine's restart loop.
You need to reflow all hairline cracks and bad solder joints on the analog board connector sockets. To do this properly, I recommend removing as much of the old solder as possible, then using a generous amount of flux and new solder. Since these joints are large, your soldering iron needs to be powerful enough to generate the heat required for a solid connection.
Do not try to move or pull the connector pins, or you could end up lifting the pads. Perform the work with the connectors plugged in; this ensures the pins on the socket will not move or become misaligned.
IMHO the safest method to remove solder from those large joints is the 'Wick and Flux' method.
