I could be incorrectly crossing over two separate discussions, but that was what I was trying to work out. A bit of jiggery-pokery on a modern machine to pre-tweak the image and a raw disk write could be the solution to all this.true. I didn't know about the other partitions but I agree completely with your assessment.
Should run in 6.0.4(ish) and up but it's untested on anything other than 7.5.5On that note, for my purposes, it would be great if I could run this in System 6, 7 or 8.1 at VERY latest. saybur, what’s the minimum OS your very alpha version will run?
Well it shouldn't but this is hot code so I'm not comfortable saying it definitely will not. It seems unlikely unless the OS maps IDE devices onto SCSI IDs or something like that.if I'm then running this on a PB1400 that boots from IDE (and has the .iso on a PCMCIA->CF card), then there's no chance it'll overwrite my boot volume?
Correct!it sounds like his Whole Disc Image includes the partition table. That would cause any system that mounts the drive to ignore the unused space because it is not mapped, but should not cause any actual problems.
That's the idea.The .iso will include an ISO <whateverthestandardnumberis> partition map, just as any other optical disc. If the PA-RISC system can boot from a CD it shouldn't have any trouble reading it.
The whole installation is on 3 CDs. So, the first .iso would contain the normal .iso partition table and the PA-RISC system should boot from it and won't see the other CDs, but that's fine.In the other thread Snial was talking about appending two other disks, so the data that would be ignored in that scenario would be two other disks, including their partition tables and data partitions. Unless the image he is writing has already been modified to have a valid partition table for all three partitions, or he is only writing the image from a single CD.
Are you sure the merge script doesn't just extend the first image and move the package files onto it?Correct!
That's the idea.
For the Debian installation, I understand that the first .iso is the core installation and the other(s) are additional packages. So, I think it should be possible to mount those on reboot based on the sector offset and then install the packages.
So, I was thinking this would be reasonable, because I did something similar when playing with a MAME-based SparcStation 1 emulator on my Mac mini 2012. I couldn't get the FD to work, but I could create a HD image with a missing partition; then mount that missing partition from within SunOS and dd to it. Then I could shutdown and from the host side, dd the data back out. It was very crude, but worked. In the future I plan to use the emulated ethernet to transfer data, now that I have a better grasp of how to link it up to virtual network interfaces on the Mac.
But thinking about it again, I might be wrong, or at least a bit wrong. I would need to mount the other .iso images as .iso's so that the target (the PA-RISC system) understands their partition maps too. Maybe that's reasonable: the other .iso s on the HD won't be on partitions on the HD, so it's not like it's partitions within partitions.
It does mean that DumbDD needs to be able to specify the target offset, which I hadn't considered earlier... though I could get around that too just by joining them all together. However, I might not do that as I might not want to write 2GB in one go, just 644MB at a time.
The Debian script it looks like it merges all .isos into a single readable image, complete with combined package lists and the like.Are you sure the merge script doesn't just extend the first image and move the package files onto it?
Aaah, OK. I'd looked at the web page talking about this and then forgot about it. So, perhaps that solves one problem: it results in a merged .iso . In this case, the .iso would be about 1.932GB I think, less than 2GB. Sorry about that.The Debian script it looks like it merges all .isos into a single readable image, complete with combined package lists and the like.
dd to copy the .iso's block by block. I'm not sure what I should use with Mac OS 8.1. I certainly don't want a partition table...I was thinking it would be strange if it didn't and the description on the page sounded like it did.The Debian script it looks like it merges all .isos into a single readable image, complete with combined package lists and the like.
It should save properly, as it would be interpreted as an entire disk.So, if I created a blank .img without a partition map I should be able to mount it on Dingus PPC; then run @saybur 's scuzImager to write a .iso to it. We don't know if it'd save it properly, but I could use scuzImager again to write it to another .iso and then compare them?
Something like this would be great and very useful. I need to get an image of a real spinning disc A/UX SCSI volume to zigzagjoe for testing/debugging purposes and currently there is no way for me to do that with the setups I have at my disposal.
SCSIInstr gScsiProg[kScsiProgLen]={
{ scNoInc, 0UL, 0UL },
{ scStop, 0UL, 0UL }
#define Wrd(aWord) ((uint8_t)((aWord>>8)&255)), ((uint8_t)(aWord&255))
#define Lng(aLong) ((uint16_t)((aLong>>16)&0xffff)), \
((uint16_t)(aLong&0xffff))
uint8_t gReadBlk[]={
6, 8, Wrd(0), 0, 0, Wrd(0),
uint8_t gWriteBlk[]={ // offsets 2, 3, 4 are the block num (big-endian)
6, 0xa, Wrd(0), 0, 0, Wrd(0),
void ScsiInit(short aId, uint8_t *aCmdBlock)
SCSIGet();
SCSISelect(aId);
SCSICmd((char*)&aCmdBlock[1], *aCmdBlock);
short ScsiFinish(int16_t *aRetMsg, uint32_t aDelay)
SCSIComplete(&gScsiStat, &gScsiMess, aDelay);
*aRetMsg=gScsiMess;
return gScsiStat;
void ScsiProgSet(SCSIInstr *aProg, uint8_t *aBuff, uint32_t aBytes)
aProg->scParam1=(uint32_t)aBuff;
aProg->scParam2=(uint32_t)aBytes;
short ScsiDoRead(int16_t *aRetMsg, uint32_t aTicks,
short aId, uint8_t *aCmdBlock,
ScsiInit( aId, aCmdBlock);
ScsiProgSet(gScsiProg, aBuff, aBytes);
SCSIRead((Ptr)gScsiProg);
return ScsiFinish(aRetMsg, aTicks);
short ScsiDoWrite(int16_t *aRetMsg, uint32_t aTicks,
SCSIWrite((Ptr)gScsiProg);
tRawCopyInfo gRawCopyInfo;
void ScsiRawCopyInit(tRawCopyInfo *aInfo, uint16_t aId, int16_t aState)
aInfo->iBlkPos=0UL;
aInfo->iId=aId;
if((aState&kRawCopyEventScsiOpMask)==kRawCopyEventScsiWrite) {
GetEOF(aInfo->iFd, &(aInfo->iLen));
else {
SetFPos(aInfo->iFd, fsFromStart, 0UL); // reset the file.
aInfo->iLenBlks=(aInfo->iLen+kBlkSize-1)>>kBlkSizeBits;
aInfo->iState=aState; //kRawCopyEventGo;
//#define kScsiRawCopyDummy
void ScsiRawCopy(tRawCopyEvent aEvent /* oops, unused*/ )
register tRawCopyInfo *info=&gRawCopyInfo;
int32_t count;
OSErr err=0;
int32_t to=In(kUpdateRate);
while(info->iLen && !After(to)) {
tBool readOp=(info->iState&kRawCopyEventScsiOpMask)==
kRawCopyEventScsiRd;
uint8_t *blkCmd=readOp? gReadBlk:gWriteBlk;
count=kBlkSize;
blkCmd[2]=(uint8_t)(info->iBlkPos>>16);
blkCmd[3]=(uint8_t)(info->iBlkPos>>8);
blkCmd[4]=(uint8_t)(info->iBlkPos&255);
if(readOp) {
#ifndef kScsiRawCopyDummy
ScsiDoRead(&gScsiMess, kStdWait, info->iId, blkCmd,
gScsiBuf, kBlkSize);
#endif
err=FSWrite(info->iFd, &count, gScsiBuf); // gScsiMess, gScsiStat
else {
FSRead(info->iFd, &count, gScsiBuf); // gScsiMess, gScsiStat
ScsiDoWrite(&gScsiMess, kStdWait, info->iId, gWriteBlk,
#endif
#ifdef kScsiRawCopyDummy
int32_t to=In(2);
while(!After(to)) {
// Delay 2 ticks.
#endif
++info->iBlkPos;
if(err==noErr && info->iLen>kBlkSize) {
info->iLen-=kBlkSize;
else {
info->iLen=0;
if(info->iLen==0) {
FSClose(info->iFd);
info->iState=kRawCopyEventDone;
info->iFd=0; // Reset FD.
AppMenuDDEnable(info);
That's an Infinite Mac error message. It's not from Snow. That's a bug for @mihai to fix.However, when I try and read from SCSI via Infinite Mac's Snow Mac IIcx emulator, I get:
