DumbDD
Snial
Moderator
Staff member
68000
Hi folks,
I've tried to ask about this a couple of times, with little response except for a suggestion to try FWB. However, in another post I found FWB CD Toolkit crashes with a Type 3 error. So, I thought I'd write (what I imagine to be) a fairly simple utility to do what I want: DumbDD, since as far as I can tell, Classic Mac OS disk copying apps are intelligent things that want to write HFS, MSDOS or ISO images or volumes to partitioned devices (which makes sense) it already understands. I want to write an ISO for a foreign CD image (Debian, PA-RISC as it happens) to a SCSI Hard disk.
DumbDD
.. would be super-simple. It has a File:Open.. dialog to open any file as a disk image file... your fault if you pick a non-disk image file. It has a Dump:To SCSI0 to :SCSI7 menu option to write the image to a given SCSI device as raw blocks.
I've been reading the docs about how to use the SCSI manager:
I think there are a few others I could use. The first one uses assembler and Forth, but I understand both and I'll convert it to 'C'. I don't need to write a driver.
Is this of any use to anyone?
“dd” for Classic Mac OS sounds like a great idea! This could help with an issue that was mentioned in a thread somewhere here around 68kmla a couple of months ago... (some versions of?) the Finder and/or OS will write a few obscure bytes to any given volume that make it difficult or impossible to get an exact binary duplicate when working "within the system". (At least, I think that was at the volume level. It _might_ have been individual files, I can't find that thread to verify.) Nobody knows what they’re for, but I can’t imagine it adversely affecting anything to bypass that activity; or you wouldn't, for example, be able to compare two optical discs for having been burned correctly.
tl,dr: This is an idea long overdue. Good thinking!
I drafted a small demo program yesterday in response to your first post to do what you're describing: single function, just write a file as a disk image to an arbitrary SCSI ID. Based on testing disk images worked fine. However, the limited number of small CD images I tried did not work, but I'm uncertain if it's a bug or a structural issue with MacOS partition on an .iso, I am ignorant about how those work. I'll mess around with it some more today and post if I get results.
Note what I'm writing is not a true `dd` replacement, that would include (at minimum, IMHO) byte/sector offsets, skips, and all the other super-useful stuff that makes it such a swiss army knife of a program.
A CD or DVD uses a different partition-map format than a hard drive, and the Mac would not be able to make sense of it unless you wrote it to something it considers to be an optical disc. I'm not sure there's any way to do that with stock software.
I guarantee this would be extremely useful, especially if you could make it so that it worked in reverse, it can create a raw block copy disk image of any given SCSI drive attached to the system.
Perfect, well done! I did wonder if someone would beat me to it, but I thought .oO( I might as well fish for a level of interest. Besides, it'll take ages for someone to write something). LOL! [ ".oO( ... )" is my symbolism for thinking, it's an ASCII thought-bubble].
I thought this was because the disk's driver is stored on a partition within an Apple Partition Map drive. Early SCSI drives couldn't work with a generic SCSI driver, which I think is partly why the second MacTech article is focussed on adapting the demo SCSI driver to work with a 280MB Quantum drive.
So, for example, I think HD SC Setup would install the driver on the drive, or an Apple-formatted drive would already come with a Mac driver installed. This also explains why, certainly in the early days, only approved drives were supported.
It also explains why a CD .iso won't work, since I wouldn't expect it to have a SCSI HD driver on a partition. It wouldn't be a problem for me as I'm writing a foreign CD file system to a disk, a Debian 5 Installation for a PA-RISC system.
But it's a great start! I've assumed you've used 'C'. Is it a THINK C, Metrowerks, MPW or Retro68 project? Is it 68K or PPC? Are you happy to publish it here or push it to git (or your preferred online repo)?
You're quite correct, there's a driver on there too. I'd somehow forgotten that detail. 3rd party drivers that tried to be more performant were a legitimate market for a while.
Makes sense. I've been spoiled by modern Linux distros being able to `dd` an image and having it "just work" most of the time.
What I've got so far is just a scuzEMU derivative. The low-level SCSI commands in/out of files was already halfway to what was needed. It's inheriting the THINK C environment and GPL, so source would be available. Assuming I can get it working properly 🤪
For @Paralel I've hacked in disk reading in the prototype, agree that'd be useful.
I guess there are PC ROM BIOSes (or EFI, or UEFI) to do that. On the Mac side we had direct ROM support for the Sony FD, then SCSI (but not specific SCSI media, as discussed earlier) and this took us to the cheapo 2-bpp, PowerBook 150 which I think was the first Mac to support IDE. The PB150 is also a spiritual cousin of the Neo so I should add a comment on that thread.
Then some other 68K Macs started supporting IDE in ROM (e.g. the Q630/Performa 630 & PB190), but then IDE support took off with early PPC Performas. Then we entered the Open-Firmware era, which allowed more boot-up media support while IDE migrated to PowerMacs (PM4400) and G3 PowerBooks and PowerMacs. Then New World took over, which made no difference as HFS/ HFS+, SCSI, IDE and now USB were now supported in OF (and every Mac from the iMac G3/DV can boot from USB with some hacking). In all these eras, booting into Linux with a foreign file system (e.g. ext2) meant providing a minimal HFS partition with a boot file, which then jumped into the Linux FS.
In the Intel era we united with PC conventions by adopting EFI, so literally the same mechanism for booting PCs worked for Macs.
Apple Silicon has another ROM architecture.
But anyway, the upshot is that all System and media Expansion ROMs on Macs, PCs, historical Unix Workstations (Sun/SGI/HP/IBM) and SBCs, provide a basic sector handling driver from which more sophisticated drivers can be located via the boot block.
Going back in time to the minicomputer era, primary bootstraps were media-specific, 10 instruction (or so) programs toggled into core that could load the boot block from the specified media and in turn bring up the OS.
So, upshot: should I have a crack at writing my own, or are you likely to release yours before I'd get anywhere? I'm actually wondering if I could write it using infinite Mac's Dingus PPC emulator ( @mihai, @joevt - are mounted drives or Saved HD SCSI drives, with proper SCSI hardware emulation?).
Here's a question: NDIF supports raw image files. Which means that, at least theoretically, if you can write something into NDIF format, Disk Copy should be able to write it out to disk. The problem currently is that Disk Copy tries to be "intelligent" about how it images a disk into NDIF format.
I like the idea of MacDD too (and a fully featured MacDD would be AWESOME), but has anyone tried writing something out via the NDIF spec yet?
Here's the prototype. This can either read SCSI devices into images (File:Read Disk) or write images to SCSI devices (File:Write Disk). Pick a SCSI ID and then a file to write/read. This is very much an alpha and it may eat all your data, please use with great caution. There are many, many caveats:
  • Testing has been performed only in MAME, no real hardware yet. I haven't tested on big devices.
  • Support is limited to <2GB image files, no big drives here.
  • No support for multiple SCSI buses, whatever ID maps to the old SCSI manager routines is what is used.
  • Volumes with blocksizes != 512 are untested but should theoretically work.
  • The name scuzImager is a placeholder, please give suggestions (or icon resources) :cool:
If anyone wants to live on the edge feel free to try this out.
EDIT: another warning: this will happily execute write commands to mounted drives (or to your boot volume if you pick that ID). Always reboot after using the write feature.
Something like this would be great and very useful. I need to get an image of a real spinning disc A/UX SCSI volume to zigzagjoe for testing/debugging purposes and currently there is no way for me to do that with the setups I have at my disposal.
On that note, for my purposes, it would be great if I could run this in System 6, 7 or 8.1 at VERY latest. saybur, what’s the minimum OS your very alpha version will run?
DingusPPC has SCSI hardware emulation. It can boot Mac OS 7.1.2 to Mac OS 9.2.2 from a virtual SCSI hard disk.
Whether it's proper or not depends on if it works with whatever you're trying to do.
If you're writing to a SCSI hard disk, note that the disk image should be blank or have an Apple Partition Map. If the disk image is an HFS or HFS+ partition with no Apple Partition Map, then DingusPPC (my fork or Infinite Mac fork) will add a read-only Apple Partition Map (maybe it's writable but the changes are temporary).
I'm not sure what parts of a Saved HD Infinite Mac's DingusPPC will save. Examine an example before starting.
So, if I created a blank .img without a partition map I should be able to mount it on Dingus PPC; then run @saybur 's scuzImager to write a .iso to it. We don't know if it'd save it properly, but I could use scuzImager again to write it to another .iso and then compare them?
Also, @saybur : if I'm then running this on a PB1400 that boots from IDE (and has the .iso on a PCMCIA->CF card), then there's no chance it'll overwrite my boot volume?
If you do exactly that, assuming it works, you'll end up with a clone of your iso, including the flags and driver partitions that define it as a CD.
Although - what format are the CDs, are they formatted with an Apple Partition Table? Or are they Linux format?
Hi @Phipli ! The whole idea is that they're raw images without an APT (I don't need the Mac to mount it after). In my case, an install .iso (Debian 5) to be copied as a .iso to a SCSI HD for a PA-RISC system. The .iso is probably 644MB, but the SCSI HD is likely 2GB. Does this help?
I'm not up to speed with how Linux does partition tables, but doesn't the partition table of whatever method it uses need updating to know about the three separate partitions you mentioned wanting to put on one disk? Less of an issue if all you want is the one partition.
it sounds like his Whole Disc Image includes the partition table. That would cause any system that mounts the drive to ignore the unused space because it is not mapped, but should not cause any actual problems.
The .iso will include an ISO <whateverthestandardnumberis> partition map, just as any other optical disc. If the PA-RISC system can boot from a CD it shouldn't have any trouble reading it.
In the other thread Snial was talking about appending two other disks, so the data that would be ignored in that scenario would be two other disks, including their partition tables and data partitions. Unless the image he is writing has already been modified to have a valid partition table for all three partitions, or he is only writing the image from a single CD.
