If you could bring back classic Mac OS software, what would it be?
Not quite the same. Today’s macOS is a kludge of useless bloat. I prefer the cleaner OS 9 and below interface.
Yep, 9.3 with upgraded USB and much larger Disk Partitions would be fabulous, no IOS crappiness.
Buggage free 9.1.1 re-release for older machines that top out at 9.1 would be quite nice as well.
Personally I like Aldus SuperPaint better than MacPaint.
And they did try to bring back HyperCard with SuperCard, but it sadly went nowhere.
I too preferred SuperPaint. SuperCard was a separate product to HyperCard, and lasted quite a long time -- the last version was 32-bit Intel, so lasted until 2019 as runnable software. It then stayed in support until 2024 when Scott passed away and the site was taken down.
I never ended up spending much time with SuperCard because it didn't have a free runtime in the early days, and then later on, everything it did could be done in a web browser in a cross-platform manner.
Oh, and then there's GraphicConverter by Thornston Lemke -- slightly more recent than SuperPaint, as it was released in 1992, but unlike SuperPaint, it's still being actively developed today (currently on version 12). And as a bonus, Thornston has made all the "classic" versions freely available - you can still download them from lemkesoft.de today, and he's provided registration codes for them.
I find it awesome that he's been able to keep a shareware product going from 1992 right through 2026 and counting.
I still use GraphicConverter, it still runs well on my M1 MAX.
There's an audio editor called SoundMaker that has enough interesting quirks that I keep returning to it. I wish I had the source code for it, or even just the SDK to write plug-ins. There's just something about the interface.
Word 5.1 was also pretty great.
I almost became an edm artist because of SoundMaster Pro, and PlayerPro … now thinking back, I wish I had.
Can I offer you an Advanced Mac Substitute? :)
Fascinating, but even getting it is the antithesis of everything Classic Mac OS related: there's no compiled application. Nothing turns me off more than wanting to try an application, and finding "type this into the terminal to compile it" without any background instructions. At that point, I just navigate away...
Interesting. Will it run Arkanoid? As you may be aware, Arkanoid won't run on a Mac that cannot be run in 24-bit addressing mode, so anything running System 7.6 or higher, or a 630 series '040 Mac, all Power Macs, and maybe the 190.
Thanks for the suggestion! Advanced Mac Substitute is 24-bit compatible, so that's no issue. I did discover an actual defect in my emulation (incorrectly setting BufPtr when alternate buffers are used). Another issue is that Arkanoid executes code stored in the alternate screen buffer, so that restriction needs to be relaxed. Also, it sets one of the interrupt handlers, so I have to allow that.
With that, I get working gameplay, although with no sound. So, more work is needed to do it justice — but not a bad outcome for the first day!
I improved the heuristics on my disassembler, allowing me to see the audio output generator. Curiously, while it uses a VBL task for graphics, rather than the typical choice of using the same task for audio, it uses the level 1 autovector interrupt instead, which isn't implemented in Advanced Mac Substitute.
But I was able to reverse-engineer and reimplement the audio generator, and now I have working sound!
So at that layer, do you side-step the audio FPU issues altogether? I'm curious how portable that approach would be to non cycle-exact emulators.
