Help for a nubus Radius PrecisionColor Pro 24X ROM/firmware upgrade
Ok, I've updated my website to collect ROMs and some info together. I was rushing the update, so forgive any mess or lack of detail. I'll make updates if people nudge me in the right direction. I'd like to keep it to primary sources if possible though folks, there is a bit too much misinformation out there already regarding these cards. I'm sure I've missed some of the ROMs and specs that are floating around, but it is a start.
I've decided that the weird green 24X cards that aren't on the normal short PCB are 8" cards, the normal short ones are 7", and the big ones of various types are 10".
Not sure if you have this image or not, but I got a PrecisionColor XP card not too long ago with a NEC rom on it (27c256). It boots with an NEC splash screen. Not sure if it's's common or not, so I thought I'd ask. I can send you a copy if you need it.
If you're able to image the ROM it would be good to add to the collection.
Sorry... It took a bit. I was quite surprised to see eetools website was gone. Maybe I should have checked for the software download before moving my burner to a different machine. If anyone needs a copy of eetools Maxloader (topmax, chipmax, etc) let me know.
Here is the copy of the NEC rom on my 24xp @Phipli . Label reads NEC.Mac.FB..24xp v1.3 256K u1200 -0061-01-A
Excellent, thank you!
