5260/120 issue
I got a 5260/120 from CL yesterday for $30. Came with Stylewriter 1500, modem etc.. After cleanup, fixing the FDD and cleaning some faulty extensions, I got it to work. Alas, after a day or so, it froze and the screen went blank, and not I cannot get it to boot any longer. The PS is OK (5 and 12V on the money and the HDD spins). Upon power on, I hear a healthy chime, but no HDD actuation noise, and a black screen. I replaced the 3.6V battery, reset the Cuda chip, to no avail. What else do I need to look at ?
Thanks in advance !
Thanks. I mostly know compact macs that still show a display when the HDD is toast, with a flashing question mark Mac. Do I understand that the 52xx Macs do not show a screen when the HDD is dead ? And would it boot with a system floppy ?
A dead HDD had crossed my mind, so I disconnected it and still got the same symptoms.....
Also pull the logic board out and check for corrosion next to the battery. The 4.5v batteries are leaking these days and cause damage to sensitive parts of the board. Mainly the SCSI, which if that was a mess might stop the machine booting even though the disk is IDE.
I have a pair of these and they are tough to work on. When you slid the logic board out to change the battery, did you look inside the slot to see if there is anything like dust or spiders blocking the connector? Possible use some contact cleaner and make sure it's slides back in properly. Also, make sure the battery you used to replace the old one is working as I believe this Mac requires one to boot. Zap the PRAM.
Yes I also checked, and there is hardly any corrosion around the battery. I removed the Velcro backing and spent 30mn inspecting all the traces, and I see nothing suspicious
3.6v? Am I going daft? Don't these have 4.5v Rayovacs from factory? If so, what did you replace it with?
I had a few 3.6V PRAM batteries for the Mac SE (1/2 AA) that have 3.6V. My understanding is that as long as it's >3V, it should be OK (mine is almost 3.7V). I'll play some more with that
I cleaned out the contacts on the board itself, but will look in as well.
By the way, I'm not sure if it has anything to do with it, but the screen went blank after I connected a Color Stylewriter 1500 to the LB. Not sure if it was right upon connecting, or later on, as I was busy checking the printer
Yup, that's fine and works, I was just confused because it sounded like you'd replaced an existing 3.6v.
Check the voltages, PSUs are failing these days. 5v is most important and you can check it from the hard disk molex, along with 12v.
Questions -
Does it chime? Do the speakers make a small "pop". Does the monitor charge with static (does a bit of paper stick to it when it powers on). What happens if you unplug the hard disk and power on? What happens if you press the programmer's reset button while it is stuck?
Yes, 5V and 12V right on the money (from HDD molex)
Does it chime?
Yes, health chime followed with some HDD noise (self test at startup)
Nothing after the chime
No. When it was still working, I could hear a CRT thump after the boot chime. Now, the CRT remains silent and dark. With a compact Mac, the CRT comes on even if the boot process fails. Would the 5260 not turn on the CRT until the LB self-test is complete ?
Same symptoms
I have reset the Cuda chip. Not sure if there is a programmer's reset button. Where is it ?
CPU, RAM and ROM are most likely fine then.
Same symptoms
Sounds like you have analogue board issues, or a bad tube. Did you or anyone possibly let the air in?
I wouldn't worry about it the reset button then - if the tube isn't static, thats where you need to direct your efforts - analogue board and tube.
Take care, the voltages are crazy high and there are capacitors that potentially hold it for some time after power off, even if unplugged
I thought about an analog board issue. But would this prevent the boot process from proceeding ? Again, the system is just not accessing the HDD, FDD, or the CD (I tried booting with a system floppy and a system CD). In compact Macs, the analog board or CRT could be completely toast, but the system would still boot
It's where I'd start as it is the biggest symptom.
Unless you have a Performa 630, in which case I'd swap the boards over and see what happens.
They do if the drive doesn't trash the bus like the drive in your machine probably is
Assuming my PS is OK (which seems to be the case), I see 3 possibilities
1) AB and LB are decoupled, and LB can boot up without a good screen, like it is for all compact Macs
2) AB needs an OK from the LB before firing up the CRT
3) LB needs an OK from the AB before booting up
It would really help me sort out my issue if someone would have an answer to this. Thanks in advance
So I went ahead and disassembled both PS and AB. It's a bit involved, but not as difficult as I thought it would be. There was quite a bit of dirt and dead bugs everywhere. One connector was (I thought) a bit loose, and I was really hopeful that was the problem. One power transistor on the AB looked a bit pale but checked OK. Alas, after everything was back together, I still had no boot. At least, I did not make it worse, and I still had the chime LOL. I went ahead and bought a Performa 6300CD LB for a reasonable price, not knowing exactly if it would be a good replacement (Gemini says it is), so we'll see if that helps
By the way, I see quite a few posts describing the same issue on many Apple desktop products from this timeframe, but no apparent, obvious resolution.
Straight swap. Basically the same thing I think... If I remember the 5260 is actually a 6300 really (has a 603e instead of a 603).
What puzzled me most about the 5260 was that the display resolution seemed to be limited to 640x480. Was that really true? I was almost on the cusp of buying one in late 1996, actually at the Apple Reseller at Manchester Uni when I discovered this and so I bailed out. My ideal PowerMac was going to be the Apus 2000, but then I saw MacUser's review of the PM4400 and figured that's everything I needed.
I'm not sure, but it seems that way based on the Dev notes.
In 1996 my main computer was a BBC Model B 😄
Well, happy to report that my system works with the spare eBay LB that I just received. So in the end, it was not an issue with the PS, the HDD or the AB. This tells us that both the HDD and the AB wait for an "All clear" signal from the LB before firing the CRT and booting up. Also noteworthy is that the system boots fines without the PRAM battery, which is NOT what you read online
