New Project: DoubleVision SE/30 Card
(How are you so fast?)
Have you considered a passthrough PDS slot and a physical card ID selection? Stacking SE/30 cards is very handy and the more cards with passthrough, the easier it is to customize (of course, you can't really get past a few cards or power and signaling issues crop up). Along with that you can have ID conflicts with multiple boards so it's common to provide jumpers or DIP switch so you can adjust before inserting.
Indeed there is no support for hardware cursor in 6/7/8. I also have the hardware cursor (albeit smaller at IIRC 32x32, a clone of what available in Brooktree DACs in SPARCstations, also with a limited number of colors) but it's only useful in X11.
At that size, if the sprite is full-color (same depth and CLUT as the display), then it could replace the SW implementation.
Even if the sprite is too shallow, you could limit it to black-and-white cursors — which is most of them. A more significant limitation would be the lack of XOR mode in the blitter, used in the I-beam cursor for example.
Maybe it could be used by hijacking some of the QD functions - but it's likely going to be quite difficult to implement.
It's not out of the question. Here's a proof of concept for how it could work:
QuickDraw per se is untouched, and no traps are patched — only some jump vectors in low memory are rerouted. That is, in fact, how it works in my reimplementation of classic Mac OS — though just how closely it resembles the real thing is a topic I haven't investigated.
"True" hardware cursor, in the style of Brooktree, don't rely on a blitter - do you use what I would describe as an "offscreen cursor" ? (stored in additional VRAM beyond the picture, perhaps alongside a copy of the area it replaces?)
In the Brooktree style, the cursor bitmap is stored directly in the DAC, alongside its coordinate. When the HW cursor is active, inside the cursor area the DAC simply ignores the data coming from the framebuffer and use those from the cursor bitmap instead wherever the cursor bitmap is not set to "transparent". The content of the framebuffer underneath the cursor is never changed at all. It's very efficient.
Interesting. Does your reimplementation only cover the original QD, or the entire Color QD ? It appears to be mostly C/C++ (with a tiny bit of 68k ASM), and it makes me wonder whether some of it could be used as the basis for acceleration code. I limited myself to low-level variant(s) of BitBlit because the upper level stuff was too complex to reimplement, but if you already have done the work it might bear revisiting...
At that size, if the sprite is full-color (same depth and CLUT as the display), then it could replace the SW implementation. Maybe it could be used by hijacking some of the QD functions - but it's likely going to be quite difficult to implement.
As I said, the hardware function exists, and perhaps it will come in handy at some point. ;) Same as with the P-Vision, I will publish a complete register description of the DoubleVision. The mouse sprite is 3 colors and has its own independent palette, so it has constant appearance no matter if a CLUT or RGB color mode is displayed.
What does that mean and what is it used for on Amigas, practically?
On Amiga, any application can open its idividual screen with its own display parameters. That by itself is nothing new, but the UI concepts of Intuition (that is how the window system is called) include the concept of draggable screens.
So each application has, similar to the MAC.. err..... Macintosh(tm) ;) , a menu bar on top (even when it is invisible), and with the mouse, you can select the menu bar, click and hold the left mouse button, and then you can move the screen up- and downwards, like a curtain.
And the Amiga display hardware can do this by just updating a so-called "Display List", which is a definition of screen regions, consisting of display memory pointers, palette CLUT entries, display attributes, etc. For that, it has its own display processor called the "Copper", which is executing a program, while the display hardware draws the screen.
I'll show you a short example here.
Here, you can see a Directory / File manager application running on its own screen:
And by clicking and holding the menu bar, i can "pull" the application down, revealing the underlying desktop screen (Workbench):
AFAIK, it's a UI concept which is pretty much unique to the Amiga. Which is why my graphics core also supports this feature. ;)
You basically can handle multiple surfaces on one display by just updating a few parameters in display memory, and it is very smooth. An 68020-based Amiga has no trouble moving screens at 60fps.
You can debate whether that's a useful feature. For me personally, I cherish it, because it's easier to go "in-between" applications, than dragging windows around on a single desktop. I guess it's a matter of personal preference.
Thinking of screens, plural, on Mac, QD basically define a massive 64Ki*64Ki (16-bits signed values) area, and each display is just a small subset of that - obviously the primary screen is anchored at (0,0). They can have their own resolution and depth independently. It's very convenient for the user but as mentioned previously, makes it less than obvious what's going on if you don't go through QD.
Of course, that is supported on my graphics core. I can even define, for each display slice, a "virtual screen", and apply a per-pixel panning (scrolling) to move over this area. This is also implemented in Amiga graphics library - example:
Paint program opening a 640x480 8-bit CLUT screen:
Next, I "drag" the screen down, revealing the workbench at 1280x720 Hi-Color - but displayed at 640x480 display resolution.
To reach other regions of the desktop, I can smoothly scroll over the virtual 1280x720 surface witout changing the display for either of the 2 screens.
And this all being accomplished WITHOUT moving a single pixel byte in memory. ;)
I'm not suggesting that these features are applicable in MacOS, it's basically what this graphics card is going to get "for free", since the core has already been developed.
