New application for Mac OS 8-9!
Hi everyone,
After working away at many projects I've finally finished one of them!
GameBox is a game library partially inspired by Steam, and is built to make the process of gaming on a vintage Mac as straight forward as possible.
My kids have struggled with the quirks of gaming on vintage Macs like having to mount virtual CDs, resolution + bit-depth changes etc., so I built something to take the complexity out of gaming. GameBox allows the creation and organisation of multiple game libraries, auto-mounting and unmounting of virtual CDs, and supports launch/exit scripts for game-specific configurations.
This application is targeted towards machines with a G3 or better, but all of my older Macs are currently packed away so I haven't been able to do extensive testing. I'm hoping it works on first-gen PPCs! An OSX release is scheduled but there are a few bugs to iron out.
Check GameBox out at the Manticore SW website.
For any bug reports/feature requests, please submit them at this URL.
I hope you find this application useful, and happy holidays!
Anyone have a serial for this? Can't find it in serialbox...
jkjk should support this dude. We've been slaving over apple script the last two years to make games work for our kids.. Need any help with it? Would be interested in contributing or testing. Me and buddy have dozens of systems on the go for our master image. Testing and scripting is our strength.
Very cool - will test out on my MDD Mac! The ultimate setup would be to package this with a bunch of games like Total Replay for the Apple II. I imagine that HD image would be pretty large though, so maybe one could just do the classics.
This is…absolutely one of the greatest things I’ve seen in years. My kids constantly ask me why a game won’t work (e.g. screen isn’t set for 256 colors, everything is “small” because the resolution isn’t 640x480), so this is absolutely amazing! Hopefully this will work on my PT Pro with G3 card!
<snip> GameBox is a game library partially inspired by Steam, and is built to make the process of gaming on a vintage Mac as straight forward as possible.
My kids have struggled with the quirks of gaming on vintage Macs<snip>
Respect! And you have an iMac Flower Power. Respect!
Happy xmas back!
Just one question: No way for this to support 7.x? I keep 7.6 on my PT Pro because there are some games that run better under it than 8 or 9.
Thanks everyone!!
@n8blz I'll have an OSX build ready for testing soon, and hopefully a 68k/System 7 build later :)
@Byte Knight I'm currently looking into building a tool to create "Game packs" which will auto-install games into the application's library, hopefully this would be a good solution.
@LaPorta Yes it's customisable and comes will a GUI tool for building scripts for games where you can pick and choose options. I can expand the built-in options if they're not sufficient. Also I haven't tested an OS lower than 8.6 (all of my machines are packed for a move in a few weeks), so you may find it works on lower systems (please let me know if you try). I'll look at a trimmed down 68k build after the OSX release
Yes I built it which REALBasic and love it haha. I'm willing to accept a slighlty larger memory footprint if it accomplishes everything I wanted and takes a fraction of the time to build. If I didn't have a busy life I would definitely opt for something else but my time is limited
Hi everyone,
Noice!! If I see you around Dunners I'll buy you a coffee.
This is superb, Instant registration. I did manage to crash it when attempting to add a folder so I'm not sure what that does
I love the scoreboard for it, really hope that gains traction! Will it display the best scores from a game from multiple people or just the highest?
What format do the virtual disks need to be? I noticed that feature didn't recognize the .img file for Capitalism
Sorry for the slow response!
If you can reproduce it crashing while adding a folder I'd be very grateful if you could share the folder you're adding so I can fix it. Adding by folder adds all game applications within a given folder. If you have an enormous game folder I wonder if it ran out of memory, I tried to keep the app as lean as possible. You could try increasing the application memory and seeing if that makes a difference?
Thanks! At the moment it just displays the top score, but I could adjust it to show multiple if that would be better?
Any format that the application Virtual CD supports, which are .CDR, .DSK, .IMG, .ISO, .TOAST. You could try re-imaging the one for Capitalism if it's not working, I'm not sure why it wouldn't recognise that. I've tried Star Wars Episode I Racer's .IMG and it worked fine. Does happen to any other .IMG images?
I'm almost finished a major update which includes a lot of performance and bug fixes, along with some big new features (including OSX release). A 68k Lite version is what I'll be working on next.
Thanks for all the effort and work you put into this.
This is something I always wanted for my classic Macs, since it reminds me a bit of iGame on the Amiga.
Really looking forward to the updates. I finally have my old Macs properly set up again, so i just got registered!
I watched the Classic Mac Gaming video again and saw the performance drop that was mentioned there, so it would be really cool to see improvements on that side.
If you need a beta tester, I have multiple machines here ranging from first-gen PPCs to late dual G4s, besides Intel machines as well.
