ITXPlus: A ITX Sized Macintosh Plus Logicboard Reproduction
An Octopart search for AS4C1M16E5-60JC shows it to be abundantly available brand new from several distributors. I bought mine on Aliexpress (brand new), but they can also be found on Amazon. Indeed, this chip could replace the onboard memory, thereby updating the LB replicas for the LC and Plus models. Could it be just leftover stock, perhaps?
BTW, this chip is the same used by Garrett’s Workshop in its 3MB RAM expansion board for the Classic.
Those are 16MBit chips (hence, I guess AS4C1M16E5-60JC), meaning 1MB x 16-bit. They're 2MB each. So, 2x DIY SIMMs with 2 chips each would provide another 8MB of DRAM, taking my LC II to 10MB (assuming fixing it is as easy as a recap?).
Port PCB's arrived (which I totally hadn't forgotten to order....) and the board has been fully tested and works just fine :)
I guess now I need to tidy up the schematic, after all I did leave this note in it :ROFLMAO:
When these are ready count me in for buying a couple off you (if you're still doing that). Have some ideas for this.
Great work!
For anyone interested, I've made a daughterboard for the ITXPlus that allows the addition of an IWM or SWIM chip in DIP-28 form. It mates with the 2x12 header on the ITXPlus and provides a pair of floppy headers, ready for your Floppy Emu, TashTwenty, or even actual floppy drive! Also made an adapter board (pictured below) in case you have a SWIM in PLCC-44 form that you want to adapt to DIP-28.
The .brd files and gerbers (see releases) are available on Github:
Just got my ITXPlus board in today (really excited, but probably won't have time to fire it up for a few weeks as I'm moving)... regarding the SWIM adapter.. any thoughts to making it in a formfactor such that it can just plug over top of the motherboard header and then exposes the floppy plug upwards or forwards?
I think that's what this board does, unless by "the floppy plug", you mean a 19-pin D-sub. That's what I would have reached for at first, but as far as I know they're unobtanium...
i meant like the board would have to be designed with the male plugs on opposite sides of the board so one can plug into the board and the other one wouldn't be sandwiched in the middle...
...Also IIRC BMOW had a whole lot of 19-pins made a while back and was looking to unload some... MAYBE?
Hi. I received the kit I ordered and am almost ready to test it, but I had a couple questions I hope someone can answer:
1) Are the "long pin" pin headers on the port board 19mm or 17mm? (I lost one. My ruler says they're 18mm on the nose, so it's off, but I don't know which way.)
2a) Any recommendations for a different brand of flux? Mine ate through the solder mask in spots and other spots are still "sticky" after several rounds with rubbing alcohol and a soft toothbrush.
2b) Regarding the flux/residue, it's acidic, right? Would a baking soda and distilled water scrub maybe be more productive than just more rubbing alcohol? Or is there something better?
3) @max1zzz specifically - When I was removing a RAM chip I soldered on backwards, I found a loose capacitor (one of the tiny SMD ones), for some reason stuck to the underside of the RAM chip. It may have been loose on my workbench from another project, but I have no idea.
I've checked the board over and while I can't find a missing cap, I also can't find account for all the caps visually (missing numbers in the sequence). Would it be possible to get a PDF of the bottom of the board, with all the birdseed searchable (and hilightable) so my terrible eyes can have a cheat sheet?
Otherwise, the build process was smooth. I "cheated" for most of the PLCC chips by tinning the pads and blasting them with a hot air solder station until they stopped moving. Which isn't the gentlest way to do it, but here's hoping I didn't break anything.
I still need to go over and check all the chip/pin continuity before I try powering it up. Maybe tomorrow.
that sounds like you're using a massively too-aggressive flux - you're not accidentally using like plumbing flux or something are you? (if so, you wouldn't be the first...). I just use ordinary pine rosin based flux, personally, and it works well enough for me (although I don't do a huge amount of SMD soldering)
This is the stuff I’m using: https://a.co/d/3Oe5oMb
It’s supposedly for circuit boards, but with all the counterfeiting, who knows?
Do you have any brand recommendations? I see DigiKey sells a pine rosin based flux made by MG chemicals, and they presumably don’t stock “questionable” brands.
The flux itself should not be acidic. I've caused cosmetic damage to masks even on careful jobs, usually from the abrasion and heat of copper braid while undoing a mistake, or from an iron's tip momentarily scuffing a dry area of the PCB during dragging. I would not think that typical rosin/tacky fluxes could erode it alone in so little time.
I usually pick SRA-TF5000, sold by Digikey and also at retail by Micro Center. It's neutral/no-clean, but I only care for peace of mind and lack of an ultrasonic, and still get it as clean as possible. Toothbrushes break up solid chunks and clear tight spots, but will then just swirl everything around, which is no good once all the alcohol evaporates and leaves everything sticky. With a lint-free/microfiber cloth or a specialized flux cleaning wipe, you can blot and wipe the remaining alcohol away before it dries. After a few passes, it should feel smooth and slick again.
I think people usually use flux paste and an oven, often a converted toaster oven, to achieve good joints during hot air reflow, rather than normal solder and flux. I'm not certain on this, though. If the PLCCs in specific are giving you trouble, though, try switching to a bevel tip for those and aiming the flat part into their legs, avoiding direct contact with the PCB/mask. This helped me out a ton for a Reloaded build.
Buying anything off Amazon where quality matters (and I mean quality in a very basic 'is it actually what it claims to be' sense) is probably a mistake.
MG are reputable as far as I know, I used to use their solder. The current flux I'm using is a TermoPasty one which I like a lot, and their fluxes seem to review well generally.
