ITXPlus: A ITX Sized Macintosh Plus Logicboard Reproduction
An Octopart search for AS4C1M16E5-60JC shows it to be abundantly available brand new from several distributors. I bought mine on Aliexpress (brand new), but they can also be found on Amazon. Indeed, this chip could replace the onboard memory, thereby updating the LB replicas for the LC and Plus models. Could it be just leftover stock, perhaps?
BTW, this chip is the same used by Garrett’s Workshop in its 3MB RAM expansion board for the Classic.
Those are 16MBit chips (hence, I guess AS4C1M16E5-60JC), meaning 1MB x 16-bit. They're 2MB each. So, 2x DIY SIMMs with 2 chips each would provide another 8MB of DRAM, taking my LC II to 10MB (assuming fixing it is as easy as a recap?).
Port PCB's arrived (which I totally hadn't forgotten to order....) and the board has been fully tested and works just fine :)
I guess now I need to tidy up the schematic, after all I did leave this note in it :ROFLMAO:
When these are ready count me in for buying a couple off you (if you're still doing that). Have some ideas for this.
Great work!
For anyone interested, I've made a daughterboard for the ITXPlus that allows the addition of an IWM or SWIM chip in DIP-28 form. It mates with the 2x12 header on the ITXPlus and provides a pair of floppy headers, ready for your Floppy Emu, TashTwenty, or even actual floppy drive! Also made an adapter board (pictured below) in case you have a SWIM in PLCC-44 form that you want to adapt to DIP-28.
The .brd files and gerbers (see releases) are available on Github:
Just got my ITXPlus board in today (really excited, but probably won't have time to fire it up for a few weeks as I'm moving)... regarding the SWIM adapter.. any thoughts to making it in a formfactor such that it can just plug over top of the motherboard header and then exposes the floppy plug upwards or forwards?
I think that's what this board does, unless by "the floppy plug", you mean a 19-pin D-sub. That's what I would have reached for at first, but as far as I know they're unobtanium...
i meant like the board would have to be designed with the male plugs on opposite sides of the board so one can plug into the board and the other one wouldn't be sandwiched in the middle...
...Also IIRC BMOW had a whole lot of 19-pins made a while back and was looking to unload some... MAYBE?
