Setting up a PC Trasporter on a IIGS
Awesome possum! Now I can start cross checking stuff.
My color switch card does nothing when connected, so I just threw a few bucks at it and replac d these parts... Let's see.
Bought the same chips with the same intent of replacing them on a (seemingly) non-working ColorSwitch... but then never found the time to do it :D - let us all know if something changes!
Anyway I guess the new ColorSwitch pcb project could be a place to look at, for finding some answers, even related to the pinout we're all trying to figure out; for instance your question:
Also, does Ground need to get connected to each of the various grounds at the DB15, or is one sufficient? (Pin1+Pin6+Pin13)
have been bugging me for a couple years already :D as I am scared to fry / mess up something with wrong connections, being a total noob with electronics.
Confirmed. I plugged a IIgs video cable into the back of a IIgs, and then measured pins 1, 6, 13, and the shield, and they all have continuity to each-other, so are all a common ground. I'll wire up my DA15 (?) the same way.
Unfortunately, even after chip replacement and proper wiring harness, i still get no IIgs video output via the colorswitch.
I'm going to hook up two monitors in parallel and see if i can get PC Transporter signs-of-life or not. Have to figure out how to get software into this machine, which is booting off of an ancient IDE type card (that has a CF card on it now). May have to borrow my son's CFFA3000 and use that to shuttle software onto it - ugh.
Progress!
Switcher doesn't work, but video output does!
Got to figure out how to configure stuff now.
The TEST feature says it's going to erase the card. What do s this mean, any concern?
Progress!
I knew it! Direct video-out signal seems to never fail.
Reading through the first posts, you will discover that under proDOS the card memory can be used as a RAM disk - in this case, testing it will erase any file saved there.
Your issue anyway seems to be with the ColorSwitch... which seems to me quite common. I would recommend to focus on setting up devices, disk images, programs etc and have fun with the PCT as much as possible - then maybe new developments of the ColorSwitch clone will help us :D
So no matter what I do, i can't get 720K 3.5" drive emulation to work via Gotek and the nanja.info adapter. How did you get this working?
Meanwhile, any chance you have a MSDOSVOL type "hard-file" that is bootable and functional so I can test with? So far, i can get this thing to pass all its tests, I can configure it "properly", but i haven't been able to get it to boot anything.
I ended up only able to fit the mostly empty 20mb dos "partition" (from the pct-connectors-rebuild github) onto my Alltech CF card's 2nd partition. But got it to boot!
I'll try a bit longer with the color switch and floppy stuff, and see if I can get anywhere further.
Then, it's all for sale!
Honestly I am not sure I ever used 720K disk images, but anyway I had to try a lot of DOS images before finding some actually working on the Gotek.
I have this zip file in my archive, that should be the MSDOSVOL I have on the USB stick plugged to the xDrive inside my IIGS. Let me know if it will work for you, otherwise I should get the actual IIGS and move the file from there. Remember to set the path to the DOS volume in the PCT panel (there should be a README file with instructions inside the zip).
