Hello.
A few days ago I received a Power Mac 6500/250 that works fine. I've installed Mac OS 7.6.1, 8.6, and 9.1 on different partitions.
I wanted to add USB and Ethernet support, so I added an NEC USB 2.0 card that I usually use in my G3 and G4, and a Realtek RTL8139B Ethernet card that I had lying around.
I used these drivers in both OS8 and OS9:
https://www.macintoshrepository.org...9c-l-rtl8139d-l-rtl8100-l-rtl8130-rtl8139b-l-
https://macintoshgarden.org/apps/usb-adapter-card-support-146
After installing the drivers, on both operating systems, System Profiler shows a USB card, but when I connect an Apple keyboard and mouse, nothing works; neither Caps Lock nor anything else lights up. The Ethernet card isn't even listed, and I don't know how to verify that the driver is making it work.
Am I missing a step? How can I at least get the USB port working?
I also have a USB/FW card that works fine on the G3 and G4. Could it work on the 6500 and give me access to the FW port?
Thanks.
Thanks.
