I'm trying to see if I can get my Wombat Quadra board to enter diagnostic mode, as seen here: https://web.archive.org/web/20140921020853/https://mac68k.info/wiki/display/mac68k/Diagnostic+Mode
I suspect Pin 156 on U16 (the IOSB) is PA0 for VIA1, which I would think should bring the system into diagnostic mode if grounded. Tracing to the bottom of the board there's a test point just off to the side to make things a little easier.
But grounding it doesn't seem to have any effect. I tried from the test point and (carefully) from the top side, as pin 155 is ground it's relatively easy to touch to it's neighbor despite those tiny legs.
No dice, it just boots normally. Any ideas?
